Sony Ericsson Xperia Pro MK16A Camera Replacement
  1. Sony Ericsson Xperia Pro MK16A Camera Replacement, Taking the Back Off: step 1, image 1 of 3 Sony Ericsson Xperia Pro MK16A Camera Replacement, Taking the Back Off: step 1, image 2 of 3 Sony Ericsson Xperia Pro MK16A Camera Replacement, Taking the Back Off: step 1, image 3 of 3
    • Use a plastic opening tool to get the back cover off your phone.
    • The plastic opener will work on any side, but be careful and pry gently.
  2. Sony Ericsson Xperia Pro MK16A Camera Replacement, Removing the Battery: step 2, image 1 of 1
    • Locate the battery in your phone.
    • Find the divot below the battery.
    • Use your thumb to lift the battery out of the phone.
  3. Sony Ericsson Xperia Pro MK16A Camera Replacement, Remove Screws: step 3, image 1 of 3 Sony Ericsson Xperia Pro MK16A Camera Replacement, Remove Screws: step 3, image 2 of 3 Sony Ericsson Xperia Pro MK16A Camera Replacement, Remove Screws: step 3, image 3 of 3
    • Remove the 4 black screws with the Phillips screwdriver.
    • Remove the 4 silver screws with the Torx screwdriver.
  4. Sony Ericsson Xperia Pro MK16A Camera Replacement, Remove Back Case: step 4, image 1 of 1
    • Insert the plastic opening tool in between the two halves of the case. Pry around the phone to detach the back case.
  5. Sony Ericsson Xperia Pro MK16A Camera Replacement, Access the Logic Board: step 5, image 1 of 3 Sony Ericsson Xperia Pro MK16A Camera Replacement, Access the Logic Board: step 5, image 2 of 3 Sony Ericsson Xperia Pro MK16A Camera Replacement, Access the Logic Board: step 5, image 3 of 3
    • Remove the last screw that is connecting the logic board using the Phillips screwdriver.
    • Undo the two ribbons.
  6. Sony Ericsson Xperia Pro MK16A Camera Replacement, Remove the Logic Board: step 6, image 1 of 3 Sony Ericsson Xperia Pro MK16A Camera Replacement, Remove the Logic Board: step 6, image 2 of 3 Sony Ericsson Xperia Pro MK16A Camera Replacement, Remove the Logic Board: step 6, image 3 of 3
    • Undo that last connector.
  7. Sony Ericsson Xperia Pro MK16A Camera Replacement, Remove Camera: step 7, image 1 of 2 Sony Ericsson Xperia Pro MK16A Camera Replacement, Remove Camera: step 7, image 2 of 2
    • Lift the camera off of its connector on the logic board.
2 other people completed this guide.
Sean Gallagher
66 Reputation
1 Guide authored
One Comment
Hi,
my Sony Ericsson Xperia Pro MK16i fell onto the stone floor and now the auto focus of the camera does not work anymore. It takes photos, but they are mostly blurred. Do you know if changing the camera part would fix this problem or is the auto focus function set in some other part than the camera itself? Thank you.
Andrea - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 975
