Sony Ericsson Z500a Logic Board Replacement
  1. Sony Ericsson Z500a Logic Board Replacement, Keypad: step 1, image 1 of 3 Sony Ericsson Z500a Logic Board Replacement, Keypad: step 1, image 2 of 3 Sony Ericsson Z500a Logic Board Replacement, Keypad: step 1, image 3 of 3
    • Remove the back cover by pulling it down, and then take out the battery.
    • Using a T6 Torx screwdriver, remove the 4 screws.
    • Keep the phone open with the back cover facing you.
  2. Sony Ericsson Z500a Logic Board Replacement: step 2, image 1 of 1
    • Use the plastic opening tool and run it between the case and the body of the device to loosen the keyboard
    • There are 2 clamps that lock the keyboard to the case (1 on each side)
  3. Sony Ericsson Z500a Logic Board Replacement: step 3, image 1 of 1
    • Flip the phone over and lift straight up on the key pad to remove it.
    • Be sure to hold the phone flat (parallel to the table) so that no loose parts fall out.
  4. Sony Ericsson Z500a Logic Board Replacement, Logic Board: step 4, image 1 of 2 Sony Ericsson Z500a Logic Board Replacement, Logic Board: step 4, image 2 of 2
    • Use the opening tool to remove the 2 ribbon wires (boxed in the photo) from the logic board.
    • Gently lift the back of the logic board and then pull outwards. Be careful not to rip the ribbon wire.
  5. Sony Ericsson Z500a Logic Board Replacement: step 5, image 1 of 2 Sony Ericsson Z500a Logic Board Replacement: step 5, image 2 of 2
    • Remove the black sim card reader and green vibrator before continuing to ensure they do not fall out.
Tim
15 Reputation
2 Guides authored
Cal Poly, Team 7-12, Maness Spring 2010 Member of Cal Poly, Team 7-12, Maness Spring 2010
CPSU-MANESS-S10S7G12
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 1,671
