Sony Ericsson xPeria Active Camera Replacement
  1. Sony Ericsson xPeria Active Camera Replacement, Remove the back cover.: step 1, image 1 of 3 Sony Ericsson xPeria Active Camera Replacement, Remove the back cover.: step 1, image 2 of 3 Sony Ericsson xPeria Active Camera Replacement, Remove the back cover.: step 1, image 3 of 3
    • Open the flaps and remove the back cover using the plastic opening device.
  2. Sony Ericsson xPeria Active Camera Replacement, Remove inside plastic battery cover.: step 2, image 1 of 2 Sony Ericsson xPeria Active Camera Replacement, Remove inside plastic battery cover.: step 2, image 2 of 2
    • Remove the battery shield with the plastic opening device.
  3. Sony Ericsson xPeria Active Camera Replacement, Remove the battery: step 3, image 1 of 2 Sony Ericsson xPeria Active Camera Replacement, Remove the battery: step 3, image 2 of 2
    • Remove the battery.
  4. Sony Ericsson xPeria Active Camera Replacement, Unfastening The Motherboard Cover: step 4, image 1 of 1
    • Unscrew the 5mm screws with the T5 head.
    • Unscrew the 6mm screw with the T6 head.
  5. Sony Ericsson xPeria Active Camera Replacement, Removing The Motherboard Cover: step 5, image 1 of 2 Sony Ericsson xPeria Active Camera Replacement, Removing The Motherboard Cover: step 5, image 2 of 2
    • Remove the black cover with the plastic opening tool.
    • Remove the headphone jack from its slot.
  6. Sony Ericsson xPeria Active Camera Replacement, Unplug the back motherboard plug.: step 6, image 1 of 2 Sony Ericsson xPeria Active Camera Replacement, Unplug the back motherboard plug.: step 6, image 2 of 2
    • Unplug the plug from the motherboard.
  7. Sony Ericsson xPeria Active Camera Replacement, Remove motherboard from device case.: step 7, image 1 of 1
    • Using the plastic opening tool, carefully pry up on the edges of the motherboard, opposite of the jacks.
  8. Sony Ericsson xPeria Active Camera Replacement, Remove the display ribbon cable: step 8, image 1 of 2 Sony Ericsson xPeria Active Camera Replacement, Remove the display ribbon cable: step 8, image 2 of 2
    • Carefully pry up on the tab holding down the display ribbon cable and remove the ribbon cable.
  9. Sony Ericsson xPeria Active Camera Replacement: step 9, image 1 of 2 Sony Ericsson xPeria Active Camera Replacement: step 9, image 2 of 2
    • Use the plastic opening tool to pry the ribbon cable away from the motherboard.
  10. Sony Ericsson xPeria Active Camera Replacement, Remove camera from device: step 10, image 1 of 2 Sony Ericsson xPeria Active Camera Replacement, Remove camera from device: step 10, image 2 of 2
    • Pull the camera out through the front of the motherboard.
Alex Tobin
406 Reputation
3 Guides authored
USF Tampa, Team 14-5, Leahy Fall 2014 Member of USF Tampa, Team 14-5, Leahy Fall 2014
USFT-LEAHY-F14S14G5
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 795
