Sony Ericsson xPeria Active Screen Replacement
  1. Sony Ericsson xPeria Active Screen Replacement, Remove the back cover.: step 1, image 1 of 3 Sony Ericsson xPeria Active Screen Replacement, Remove the back cover.: step 1, image 2 of 3 Sony Ericsson xPeria Active Screen Replacement, Remove the back cover.: step 1, image 3 of 3
    • Open the flaps and remove the back cover using the plastic opening device.
  2. Sony Ericsson xPeria Active Screen Replacement, Remove inside plastic battery cover.: step 2, image 1 of 2 Sony Ericsson xPeria Active Screen Replacement, Remove inside plastic battery cover.: step 2, image 2 of 2
    • Remove the battery shield with the plastic opening device.
  3. Sony Ericsson xPeria Active Screen Replacement, Remove the battery: step 3, image 1 of 2 Sony Ericsson xPeria Active Screen Replacement, Remove the battery: step 3, image 2 of 2
    • Remove the battery.
  4. Sony Ericsson xPeria Active Screen Replacement, Unfastening The Motherboard Cover: step 4, image 1 of 1
    • Unscrew the 5mm screws with the T5 head.
    • Unscrew the 6mm screw with the T6 head.
  5. Sony Ericsson xPeria Active Screen Replacement, Removing The Motherboard Cover: step 5, image 1 of 2 Sony Ericsson xPeria Active Screen Replacement, Removing The Motherboard Cover: step 5, image 2 of 2
    • Remove the black cover with the plastic opening tool.
    • Remove the headphone jack from its slot.
  6. Sony Ericsson xPeria Active Screen Replacement, Screen: step 6, image 1 of 2 Sony Ericsson xPeria Active Screen Replacement, Screen: step 6, image 2 of 2
    • Unplug the power cable by carefully prying it away from the motherboard.
  7. Sony Ericsson xPeria Active Screen Replacement: step 7, image 1 of 2 Sony Ericsson xPeria Active Screen Replacement: step 7, image 2 of 2
    • Remove the power strip on the back side of the motherboard.
  8. Sony Ericsson xPeria Active Screen Replacement, Remove back screen shield: step 8, image 1 of 2 Sony Ericsson xPeria Active Screen Replacement, Remove back screen shield: step 8, image 2 of 2
    • Remove the shield.
  9. Sony Ericsson xPeria Active Screen Replacement, Remove the screen module: step 9, image 1 of 2 Sony Ericsson xPeria Active Screen Replacement, Remove the screen module: step 9, image 2 of 2
    • Push the screen through the front of the case, gently.
    • It may be a little tough, just work your way around the edges of the screen until it separates from the main case.
5 other people completed this guide.
Alex Tobin
406 Reputation
3 Guides authored
USF Tampa, Team 14-5, Leahy Fall 2014 Member of USF Tampa, Team 14-5, Leahy Fall 2014
USFT-LEAHY-F14S14G5
3 Members
5 Guides authored
One Comment
hi can you add explain
abdnour master2 - Reply
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 12
All Time: 2,371
