Sony Ericsson xPeria Active Speaker Replacement
  1. Sony Ericsson xPeria Active Speaker Replacement, Remove the back cover.: step 1, image 1 of 3 Sony Ericsson xPeria Active Speaker Replacement, Remove the back cover.: step 1, image 2 of 3 Sony Ericsson xPeria Active Speaker Replacement, Remove the back cover.: step 1, image 3 of 3
    • Open the flaps and remove the back cover using the plastic opening device.
  2. Sony Ericsson xPeria Active Speaker Replacement, Remove inside plastic battery cover.: step 2, image 1 of 2 Sony Ericsson xPeria Active Speaker Replacement, Remove inside plastic battery cover.: step 2, image 2 of 2
    • Remove the battery shield with the plastic opening device.
  3. Sony Ericsson xPeria Active Speaker Replacement, Remove the battery: step 3, image 1 of 2 Sony Ericsson xPeria Active Speaker Replacement, Remove the battery: step 3, image 2 of 2
    • Remove the battery.
  4. Sony Ericsson xPeria Active Speaker Replacement, Unfastening The Motherboard Cover: step 4, image 1 of 1
    • Unscrew the 5mm screws with the T5 head.
    • Unscrew the 6mm screw with the T6 head.
  5. Sony Ericsson xPeria Active Speaker Replacement, Removing The Motherboard Cover: step 5, image 1 of 2 Sony Ericsson xPeria Active Speaker Replacement, Removing The Motherboard Cover: step 5, image 2 of 2
    • Remove the black cover with the plastic opening tool.
    • Remove the headphone jack from its slot.
  6. Sony Ericsson xPeria Active Speaker Replacement, Speaker: step 6, image 1 of 2 Sony Ericsson xPeria Active Speaker Replacement, Speaker: step 6, image 2 of 2
    • Carefully pry the power cable away from the motherboard.
  7. Sony Ericsson xPeria Active Speaker Replacement: step 7, image 1 of 1
    • Pry the motherboard out of the case.
  8. Sony Ericsson xPeria Active Speaker Replacement: step 8, image 1 of 1
    • Remove the power cable from the backside of the motherboard.
  9. Sony Ericsson xPeria Active Speaker Replacement: step 9, image 1 of 1
    • The speaker can be seen in the top middle area on the reverse of the screen.
  10. Sony Ericsson xPeria Active Speaker Replacement: step 10, image 1 of 1
    • Use the plastic opening tool to carefully pry the speaker away from the phone.
2 other people completed this guide.
Daniel
437 Reputation
2 Guides authored
USF Tampa, Team 14-5, Leahy Fall 2014 Member of USF Tampa, Team 14-5, Leahy Fall 2014
USFT-LEAHY-F14S14G5
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 872
