Sony Ericsson z300 Keypad Replacement
  1. Sony Ericsson z300 Keypad Replacement, Back Phone Cover: step 1, image 1 of 1
    • To remove the back cover, use your thumb to press down on the center of case and slide it off.
  2. Sony Ericsson z300 Keypad Replacement, Battery: step 2, image 1 of 1
    • Using a fingernail lift the battery out of the phone.
  3. Sony Ericsson z300 Keypad Replacement, Sim Card: step 3, image 1 of 1
    • Slide the sim card out with your thumb.
  4. Sony Ericsson z300 Keypad Replacement, Back Dark Grey Case: step 4, image 1 of 1
    • To remove the back case first remove the four screws shown with a T5 Torx screwdriver
  5. Sony Ericsson z300 Keypad Replacement: step 5, image 1 of 1
    • Using your fingernail lift up the side of the casing around the bottom of the phone to release all five of the clips.
  6. Sony Ericsson z300 Keypad Replacement: step 6, image 1 of 1
    • Lift up towards the bottom and slide the case off.
  7. Sony Ericsson z300 Keypad Replacement, Motherboard: step 7, image 1 of 1
    • Use a plastic opening tool to lift up the brass colored panel.
  8. Sony Ericsson z300 Keypad Replacement: step 8, image 1 of 1
    • Flip up the yellow tab using a plastic opening tool to disconnect the motherboard from the phone body.
  9. Sony Ericsson z300 Keypad Replacement: step 9, image 1 of 1
    • Work the plastic opening tool around the edges of the motherboard to release it from the clips.
  10. Sony Ericsson z300 Keypad Replacement, Keypad: step 10, image 1 of 1
    • Using a plastic opening tool lift up the keypad to remove it.
Alex Serventi
65 Reputation
13 Guides authored
Cal Poly, Team 5-15, Maness Fall 2010 Member of Cal Poly, Team 5-15, Maness Fall 2010
CPSU-MANESS-F10S5G15
4 Members
26 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 1,351
