Sony Ericsson z300 Vibrator Replacement
  1. Sony Ericsson z300 Vibrator Replacement, Back Phone Cover: step 1, image 1 of 1
    • To remove the back cover, use your thumb to press down on the center of case and slide it off.
  2. Sony Ericsson z300 Vibrator Replacement, Battery: step 2, image 1 of 1
    • Using a fingernail lift the battery out of the phone.
  3. Sony Ericsson z300 Vibrator Replacement, Front Phone Cover: step 3, image 1 of 1
    • To remove the front cover, lift up the case with a fingernail in the small slot as shown.
  4. Sony Ericsson z300 Vibrator Replacement, Front Dark Grey Case: step 4, image 1 of 1
    • To remove the front grey case, remove the two screws shown with a T5 Torx Screwdriver.
  5. Sony Ericsson z300 Vibrator Replacement: step 5, image 1 of 1
    • Pry up the dark grey case with your fingernail until all four snaps around the top are loose.
  6. Sony Ericsson z300 Vibrator Replacement: step 6, image 1 of 1
    • Lift up towards the bottom and slide the case off.
  7. Sony Ericsson z300 Vibrator Replacement, Screens: step 7, image 1 of 1
    • Use a plastic opening tool to lift the black tape off of the ribbon cable connector.
  8. Sony Ericsson z300 Vibrator Replacement: step 8, image 1 of 1
    • Lift the ribbon cable connector lock using a plastic opening tool.
  9. Sony Ericsson z300 Vibrator Replacement: step 9, image 1 of 2 Sony Ericsson z300 Vibrator Replacement: step 9, image 2 of 2
    • Slide the black ribbon cable tray out with a plastic opening tool.
    • Shown in the second picture is the try already slid out.
  10. Sony Ericsson z300 Vibrator Replacement: step 10, image 1 of 2 Sony Ericsson z300 Vibrator Replacement: step 10, image 2 of 2
    • Slide the ribbon cable out of the connector.
    • Shown in the second picture is the cable already out.
  11. Sony Ericsson z300 Vibrator Replacement: step 11, image 1 of 1
    • Use a plastic opening tool to lift up on the screen board and release the clips holding it in place.
    • Lift the entire board out of the phone to remove both screens.
  12. Sony Ericsson z300 Vibrator Replacement, Vibrator: step 12, image 1 of 1
    • Use a plastic opening tool to lift the vibrator out of its slot.
Alex Serventi
65 Reputation
13 Guides authored
Cal Poly, Team 5-15, Maness Fall 2010 Member of Cal Poly, Team 5-15, Maness Fall 2010
CPSU-MANESS-F10S5G15
4 Members
26 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 2,171
