Sony FDL-220R Watchman Button Replacement
  1. Sony FDL-220R Watchman Button Replacement, Remove battery cover and batteries: step 1, image 1 of 2 Sony FDL-220R Watchman Button Replacement, Remove battery cover and batteries: step 1, image 2 of 2
    • Press down on the textured area and push towards the bottom of the device.
    • Gently remove the battery cover.
    • Remove the three AA batteries.
  2. Sony FDL-220R Watchman Button Replacement, Remove screws: step 2, image 1 of 2 Sony FDL-220R Watchman Button Replacement, Remove screws: step 2, image 2 of 2
    • Locate the five 5x11mm screws surrounding the battery compartment.
    • Remove screws with a Philips #00 screwdriver.
  3. Sony FDL-220R Watchman Button Replacement, Remove back casing: step 3, image 1 of 2 Sony FDL-220R Watchman Button Replacement, Remove back casing: step 3, image 2 of 2
    • Grasp the entire back half of the Watchman's casing.
    • Snap off the casing from the bottom of the device.
    • Gently pull off entire back casing.
  4. Sony FDL-220R Watchman Button Replacement, Remove circuit board: step 4, image 1 of 3 Sony FDL-220R Watchman Button Replacement, Remove circuit board: step 4, image 2 of 3 Sony FDL-220R Watchman Button Replacement, Remove circuit board: step 4, image 3 of 3
    • Carefully grasp the entire circuit board.
    • Pull the circuit board off of the device's plastic casing.
  5. Sony FDL-220R Watchman Button Replacement, Remove/Replace Buttons: step 5, image 1 of 2 Sony FDL-220R Watchman Button Replacement, Remove/Replace Buttons: step 5, image 2 of 2
    • Locate the thee plastic buttons/switches on the sides of the plastic grey casing.
    • Buttons/switches should be simply resting in their slots on the device.
    • Remove all three buttons/switches.
    • If the buttons/switches are dirty, clean them in warm water and dry thoroughly.
    • If one of the buttons/switches is broken, simply replace it with a new one.
    • When replacing, make sure that the slot on the switches faces up.
Sam Putnam
484 Reputation
4 Guides authored
Baylor, Team 4-5, Williams Fall 2014 Member of Baylor, Team 4-5, Williams Fall 2014
BU-WILLIAMS-F14S4G5
4 Members
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 360
