Sony Handycam DCR-DVD103 Lens Replacement
  1. Sony Handycam DCR-DVD103 Lens Replacement, Battery: step 1, image 1 of 1
    • Images do not show the camera's battery.
    • On the back of the camera beneath the viewfinder, locate the battery pack.
    • Press the small button.
    • Slide the switch forward.
  2. Sony Handycam DCR-DVD103 Lens Replacement: step 2, image 1 of 1
    • Remove the battery from the camera.
    • To reinsert the battery, slide the battery into the camera.
  3. Sony Handycam DCR-DVD103 Lens Replacement, Outer Cover: step 3, image 1 of 1
    • Using a #00 Phillips screwdriver, remove the six 4.5 mm screws from the camera's bottom.
  4. Sony Handycam DCR-DVD103 Lens Replacement: step 4, image 1 of 2 Sony Handycam DCR-DVD103 Lens Replacement: step 4, image 2 of 2
    • Remove the three 4.5 mm screws beneath the battery.
    • Remove the 2.9 mm screw from the right corner.
    • Remove the two 4.5 mm screws from the battery's right wall.
    • Images do not show the battery.
  5. Sony Handycam DCR-DVD103 Lens Replacement: step 5, image 1 of 1
    • Remove the 4.5 mm screw under the output flap on the front of the camera below the lens.
  6. Sony Handycam DCR-DVD103 Lens Replacement: step 6, image 1 of 2 Sony Handycam DCR-DVD103 Lens Replacement: step 6, image 2 of 2
    • Remove the two 4.5 mm screws at the top of the camera.
    • Remove the 4.5 mm screw from the disk side of the camera (next to the lens).
  7. Sony Handycam DCR-DVD103 Lens Replacement: step 7, image 1 of 2 Sony Handycam DCR-DVD103 Lens Replacement: step 7, image 2 of 2
    • Extend the gray viewfinder, then gently remove the black plastic casing.
    • Caution: Plastic pieces are fragile.
  8. Sony Handycam DCR-DVD103 Lens Replacement: step 8, image 1 of 1
    • Remove the two 2.9 mm screws under the black plastic casing.
  9. Sony Handycam DCR-DVD103 Lens Replacement: step 9, image 1 of 1
    • Gently pull apart the outer silver case and screen.
    • Remove the copper wire strip to detach the case from the camera.
  10. Sony Handycam DCR-DVD103 Lens Replacement, Lens: step 10, image 1 of 1
    • Remove the 4.5 mm thread that connects the lens to the camera body.
  11. Sony Handycam DCR-DVD103 Lens Replacement: step 11, image 1 of 2 Sony Handycam DCR-DVD103 Lens Replacement: step 11, image 2 of 2
    • Remove the two 4.5 mm screws from the bottom left and top left of the lens casing.
    • Remove the two 2.9 mm screws from the top right and bottom right of the lens casing.
  12. Sony Handycam DCR-DVD103 Lens Replacement: step 12, image 1 of 1
    • Gently slide the ribbon cables away from their connections on the motherboard.
    • Caution: Too much force will tear the cables.
  13. Sony Handycam DCR-DVD103 Lens Replacement: step 13, image 1 of 1
    • Remove the 4.5 mm screw that connects the camera body to the lens on the DVD side of the camera.
  14. Sony Handycam DCR-DVD103 Lens Replacement: step 14, image 1 of 3 Sony Handycam DCR-DVD103 Lens Replacement: step 14, image 2 of 3 Sony Handycam DCR-DVD103 Lens Replacement: step 14, image 3 of 3
    • Remove the five 2.9 mm screws connected to the circuit board.
    • Remove the circuit board from the camera.
    • Remove the five copper wires attached to the circuit board.
  15. Sony Handycam DCR-DVD103 Lens Replacement: step 15, image 1 of 2 Sony Handycam DCR-DVD103 Lens Replacement: step 15, image 2 of 2
    • Unscrew the three 2.9 mm black screws to remove the metal bracket from the lens.
  16. Sony Handycam DCR-DVD103 Lens Replacement: step 16, image 1 of 2 Sony Handycam DCR-DVD103 Lens Replacement: step 16, image 2 of 2
    • Remove the two silver 4.5 mm screws from the bottom of the lens.
    • Caution: Be careful with the lens once the screws are removed. The lens contains a small piece of glass that can fall out.
2 other people completed this guide.
kaitlin
342 Reputation
3 Guides authored
Cal Poly, Team 7-44, Regan Winter 2011 Member of Cal Poly, Team 7-44, Regan Winter 2011
CPSU-REGAN-W11S7G44
5 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 15
All Time: 4,632
