Sony Handycam FDR-AX33 Eyepiece Replacement
  1. Sony Handycam FDR-AX33 Eyepiece Replacement, Panel: step 1, image 1 of 2 Sony Handycam FDR-AX33 Eyepiece Replacement, Panel: step 1, image 2 of 2
    • Remove the battery by pushing the latch towards the body of the camera. Push the battery down and pull it out.
    • Remove the six black 4 mm Phillips #00 screws from the bottom panel of the camera.
    • Pull off the bottom panel. It may be difficult, but tugging on it shouldn't cause harm to yourself or the device.
    • Be sure to un-velcro the handle strap.
  2. Sony Handycam FDR-AX33 Eyepiece Replacement: step 2, image 1 of 3 Sony Handycam FDR-AX33 Eyepiece Replacement: step 2, image 2 of 3 Sony Handycam FDR-AX33 Eyepiece Replacement: step 2, image 3 of 3
    • Remove the 3 mm Phillips #00 screw from the bottom of the camera.
    • Remove the 4 mm Phillips #00 screw from the right panel.
    • Pull the right panel off. Again, it might be difficult, but pulling hard shouldn't harm you or the camera.
    • You may have to use the opening tool to remove this panel.
  3. Sony Handycam FDR-AX33 Eyepiece Replacement: step 3, image 1 of 2 Sony Handycam FDR-AX33 Eyepiece Replacement: step 3, image 2 of 2
    • Remove the two 4 mm Phillips #00 screws from the top right corner of the camera.
    • Remove the 4 mm Phillips #00 screw from in front of the flash mount.
  4. Sony Handycam FDR-AX33 Eyepiece Replacement: step 4, image 1 of 2 Sony Handycam FDR-AX33 Eyepiece Replacement: step 4, image 2 of 2
    • Remove the 3 mm Phillips #00 screw from below the right side of the battery slot.
    • Remove the black 5 mm Phillips #00 screw from the top of the battery slot.
  5. Sony Handycam FDR-AX33 Eyepiece Replacement: step 5, image 1 of 3 Sony Handycam FDR-AX33 Eyepiece Replacement: step 5, image 2 of 3 Sony Handycam FDR-AX33 Eyepiece Replacement: step 5, image 3 of 3
    • Remove the three 4 mm Phillips #00 screws from the left panel underneath the display screen.
    • You’ll need to extend the eyepiece by pulling it out from the body of the camera.
    • Pull the top panel off of the device with the iFixit opening tool.
  6. Sony Handycam FDR-AX33 Eyepiece Replacement: step 6, image 1 of 3 Sony Handycam FDR-AX33 Eyepiece Replacement: step 6, image 2 of 3 Sony Handycam FDR-AX33 Eyepiece Replacement: step 6, image 3 of 3
    • Remove the top and bottom 4 mm Phillips #00 screws from the display screen hinge.
    • Use the iFixit opening tool to remove the screen hinge.
  7. Sony Handycam FDR-AX33 Eyepiece Replacement: step 7, image 1 of 2 Sony Handycam FDR-AX33 Eyepiece Replacement: step 7, image 2 of 2
    • Remove the 3 mm Phillips #00 screw from between the eyepiece and the panel directly to the right of the battery slot.
    • Angle the eyepiece up to reach the screw with the screwdriver.
    • Take the panel directly to the right of the battery slot off of the camera.
  8. Sony Handycam FDR-AX33 Eyepiece Replacement: step 8, image 1 of 3 Sony Handycam FDR-AX33 Eyepiece Replacement: step 8, image 2 of 3 Sony Handycam FDR-AX33 Eyepiece Replacement: step 8, image 3 of 3
    • Remove the 4 mm Phillips #00 screw above and to the right of the battery slot.
    • Pry the left panel out at an angle by pushing the plastic slat between the battery slot and the eyepiece.
    • Wiggle the left panel and pull it out gently.
    • The left panel can be hard to remove so make sure to apply a good amount of force, but be cautious to not harm yourself or the device.
  9. Sony Handycam FDR-AX33 Eyepiece Replacement, Zoom, Photo, and Record Button: step 9, image 1 of 3 Sony Handycam FDR-AX33 Eyepiece Replacement, Zoom, Photo, and Record Button: step 9, image 2 of 3 Sony Handycam FDR-AX33 Eyepiece Replacement, Zoom, Photo, and Record Button: step 9, image 3 of 3
    • Remove the two 3 mm Phillips screws directly in front of the zoom button.
    • Slide the blue copper PCB out of the connector.
  10. Sony Handycam FDR-AX33 Eyepiece Replacement: step 10, image 1 of 2 Sony Handycam FDR-AX33 Eyepiece Replacement: step 10, image 2 of 2
    • Unclip the black plastic piece from behind the record button in order to remove the photo, record, and zoom buttons.
    • Use the black nylon spudger to remove the record button.
  11. Sony Handycam FDR-AX33 Eyepiece Replacement, Eyepiece: step 11, image 1 of 1
    • Remove the two 3 mm Phillips #00 screws in front of the two screws you removed in the previous step.
    • Remove the 3 mm Phillips #00 screw to the right of the eyepiece.
    • Remove the 4 mm Phillips #00 screw to the left of the eyepiece.
  12. Sony Handycam FDR-AX33 Eyepiece Replacement: step 12, image 1 of 2 Sony Handycam FDR-AX33 Eyepiece Replacement: step 12, image 2 of 2
    • Pull up on the copper PCB wire attaching the eyepiece to the body of the camera.
    • Copper PCB wire breaks very easily, use extreme caution when removing it. Be sure not to bend or twist the PCB wire.
    • Remove the eyepiece from the body of the camera.
Lee Conway
184 Reputation
2 Guides authored
Cal Poly, Team S18-G2, White Winter 2019 Member of Cal Poly, Team S18-G2, White Winter 2019
CPSU-WHITE-W19S18G2
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 13
All Time: 759
