Sony Handycam HDR-CX675 Lens Cover Panel Replacement
  1. Sony Handycam HDR-CX675 Lens Cover Panel Replacement, Camera Shell: step 1, image 1 of 1
    • The battery should be removed and oriented upwards.
  2. Sony Handycam HDR-CX675 Lens Cover Panel Replacement: step 2, image 1 of 1
    • Remove the side 4.5 mm JIS #00 screw using JIS Screwdriver
    • Remove the 5.5 mm JIS #00 screw.
  3. Sony Handycam HDR-CX675 Lens Cover Panel Replacement: step 3, image 1 of 2 Sony Handycam HDR-CX675 Lens Cover Panel Replacement: step 3, image 2 of 2
    • Gently pry the plastic case surrounding the start/stop button free by using the blue plastic opening tools.
    • Remove the casing using your thumb and index finger.
  4. Sony Handycam HDR-CX675 Lens Cover Panel Replacement: step 4, image 1 of 1
    • Turn the camera around and flip open the LCD screen to expose the side panel.
    • Remove the 5.5mm #00 screw using the J00 head screwdriver.
  5. Sony Handycam HDR-CX675 Lens Cover Panel Replacement: step 5, image 1 of 1
    • Turn the camera to the handgrip side and unscrew two of the 5.5mm JIS #00 head screws using the JIS #00 head screwdriver.
  6. Sony Handycam HDR-CX675 Lens Cover Panel Replacement: step 6, image 1 of 1
    • Remove the two 5.5mm JIS #00 screws with the bottom of the camera facing up.
  7. Sony Handycam HDR-CX675 Lens Cover Panel Replacement: step 7, image 1 of 1
    • Turn the camera around in a way that the bottom of the camera is facing you.
    • Use the blue opening tool to gently remove the camera shell off of the camera.
  8. Sony Handycam HDR-CX675 Lens Cover Panel Replacement, Lens Cover Panel: step 8, image 1 of 1
    • Using the blue plastic opener smoothly to take the camera shell off.
  9. Sony Handycam HDR-CX675 Lens Cover Panel Replacement: step 9, image 1 of 2 Sony Handycam HDR-CX675 Lens Cover Panel Replacement: step 9, image 2 of 2
    • Let the lens of the camera be pointed to your left.
    • Keep holding the camera with your right hand then gently remove the lens cover panel with your left hand.
Laith Al Hinai
161 Reputation
1 Guide authored
USF Tampa, Team 8-2, Eyestone Spring 2017 Member of USF Tampa, Team 8-2, Eyestone Spring 2017
USFT-EYESTONE-S17S8G2
3 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 14
All Time: 846
