Sony ICF-C1iPMK2 Speaker Replacement
  1. Sony ICF-C1iPMK2 Speaker Replacement, Speaker: step 1, image 1 of 2 Sony ICF-C1iPMK2 Speaker Replacement, Speaker: step 1, image 2 of 2
    • Unscrew the 1 cm Phillips #00 screws.
    • Use spudger to loosen the back panel of the device.
  2. Sony ICF-C1iPMK2 Speaker Replacement: step 2, image 1 of 3 Sony ICF-C1iPMK2 Speaker Replacement: step 2, image 2 of 3 Sony ICF-C1iPMK2 Speaker Replacement: step 2, image 3 of 3
    • This step contains ribbon cables. Be careful to not bend or rip these fragile cables, to protect your device.
    • Slowly pull the back panel off until it separated from the main panel.
    • Carefully unplug all of the ribbon cables connecting the back panel to the main panel.
  3. Sony ICF-C1iPMK2 Speaker Replacement: step 3, image 1 of 3 Sony ICF-C1iPMK2 Speaker Replacement: step 3, image 2 of 3 Sony ICF-C1iPMK2 Speaker Replacement: step 3, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the power connector with a pair of ESD safe tweezers.
    • Remove the Aux port connector with a pair of ESD safe tweezers.
    • Slide the button panels out of the chassis.
  4. Sony ICF-C1iPMK2 Speaker Replacement: step 4, image 1 of 3 Sony ICF-C1iPMK2 Speaker Replacement: step 4, image 2 of 3 Sony ICF-C1iPMK2 Speaker Replacement: step 4, image 3 of 3
    • Unscrew the four 1 cm Phillips #00 screws and remove the speaker cover.
    • Unscrew the 1 cm Phillips #00 screws holding the speaker in place.
    • Remove the old speaker and insert the new one.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 87
