Sony NEX-5R Front Case Replacement
Emily Trujillo
Emily Trujillo and 7 other contributors
Last updated on February 10, 2021
5 minutes
Easy
Introduction
Go to step 1
We will be teaching you the proper way to disassemble your Sony NEX-5R so that you can replace your front case. This will be helpful to those that have damaged the front case and are looking to fix it by themselves.
Tools
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
  1. Sony NEX-5R Front Case Replacement, Front Case: step 1, image 1 of 2 Sony NEX-5R Front Case Replacement, Front Case: step 1, image 2 of 2
    • Open the battery pack door by moving the slider to "OPEN".
    • Remove the 3.25 mm silver screw inside the battery pack with a Phillips screwdriver.
  2. Sony NEX-5R Front Case Replacement: step 2, image 1 of 1
    • Remove the 3.25 mm exterior screw with a Phillips screwdriver.
  3. Sony NEX-5R Front Case Replacement: step 3, image 1 of 2 Sony NEX-5R Front Case Replacement: step 3, image 2 of 2
    • Use the spudger to raise the corner of the case from the camera.
    • One component of the front case should now be separate from the camera.
3 other people completed this guide.
Emily Trujillo
1,114 Reputation
6 Guides authored
Cal Poly, Team 8-9, Regan Spring 2014 Member of Cal Poly, Team 8-9, Regan Spring 2014
CPSU-REGAN-S14S8G9
4 Members
14 Guides authored
One Comment
Can anybody tell me where I can purchase the replacement part used in this video - Regards
Chris
Chris Brookes - Reply
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 24
All Time: 2,257
