Sony NEX-5R Lens Mount Replacement
  1. Sony NEX-5R Lens Mount Replacement, Lens Mount: step 1, image 1 of 2 Sony NEX-5R Lens Mount Replacement, Lens Mount: step 1, image 2 of 2
    • Hold lens and camera securely with two hands.
    • With the hand holding the camera, push down on the lens button. Twist the lens counterclockwise and pull out to release lens.
  2. Sony NEX-5R Lens Mount Replacement: step 2, image 1 of 1
    • Using your screwdriver, remove the four (3.5 mm) Phillips screws on the front face of the lens mount.
    • Make sure to keep track of these screws and not misplace them.
  3. Sony NEX-5R Lens Mount Replacement: step 3, image 1 of 1
    • Remove the silver plate by gently pinching with your fingers.
  4. Sony NEX-5R Lens Mount Replacement: step 4, image 1 of 1
    • Now the black plate should be exposed. You can remove this again by gently pinching with your fingers and lifting up.
  5. Sony NEX-5R Lens Mount Replacement: step 5, image 1 of 1
    Tool used on this step:
    Buy
    • Using the tweezers, grab the thin silver ring and lift up.
  6. Sony NEX-5R Lens Mount Replacement: step 6, image 1 of 1
    • The camera mount should now be barren and look like this.
Emily Trujillo
1,153 Reputation
6 Guides authored
Cal Poly, Team 8-9, Regan Spring 2014 Member of Cal Poly, Team 8-9, Regan Spring 2014
CPSU-REGAN-S14S8G9
4 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 30
All Time: 2,901
