Sony NEX-5R Main Navigation Button Replacement
  1. Sony NEX-5R Main Navigation Button Replacement, Rear Case: step 1, image 1 of 1
    • Remove the three (3.5 mm) screws from the bottom of the camera with the Phillips screwdriver.
  2. Sony NEX-5R Main Navigation Button Replacement: step 2, image 1 of 1
    • Open the HDMI port, and remove the the two (3.5 mm) Phillips screws exposed on that side.
  3. Sony NEX-5R Main Navigation Button Replacement: step 3, image 1 of 1
    • Remove the two 4mm screws from the interior of the battery pack, and one 3.5mm screw from beside it.
  4. Sony NEX-5R Main Navigation Button Replacement: step 4, image 1 of 1
    • Looking at the bottom of the camera, use the spudger to lift the rear case away from the camera body.
  5. Sony NEX-5R Main Navigation Button Replacement: step 5, image 1 of 2 Sony NEX-5R Main Navigation Button Replacement: step 5, image 2 of 2
    • Using the spudger again, carefully pry from the top of the camera to remove the back frame.
    • The back frame is fragile, so use the spudger gently.
  6. Sony NEX-5R Main Navigation Button Replacement: step 6, image 1 of 1
    • The back case should now be removed and look like this.
  7. Sony NEX-5R Main Navigation Button Replacement, Main Navigation Button: step 7, image 1 of 1
    • Use spudger to pull the lead out from its housing.
  8. Sony NEX-5R Main Navigation Button Replacement: step 8, image 1 of 2 Sony NEX-5R Main Navigation Button Replacement: step 8, image 2 of 2
    Tool used on this step:
    Buy
    • Squeeze the lead with the tweezers and hold the lead teeth tightly with your fingers. Pull straight out to disconnect.
  9. Sony NEX-5R Main Navigation Button Replacement: step 9, image 1 of 2 Sony NEX-5R Main Navigation Button Replacement: step 9, image 2 of 2
    • The navigation button component should now be separate and able to be replaced with new component. The camera and navigation button should appear as shown.
3 other people completed this guide.
Emily Trujillo
1,153 Reputation
6 Guides authored
Cal Poly, Team 8-9, Regan Spring 2014 Member of Cal Poly, Team 8-9, Regan Spring 2014
CPSU-REGAN-S14S8G9
4 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 40
All Time: 4,580
