Sony NEX-7 Lens Mount Replacement
  1. Sony NEX-7 Lens Mount Replacement, Battery: step 1, image 1 of 2 Sony NEX-7 Lens Mount Replacement, Battery: step 1, image 2 of 2
    • We need to turn off the camera because we are removing components that could get damaged if the power is still on.
    • If the camera is on, rotate the power switch on top of the camera counterclockwise to turn the camera off.
  2. Sony NEX-7 Lens Mount Replacement: step 2, image 1 of 1
    • Flip the camera over such that the power switch points down.
    • Slide the switch on the bottom of the camera grip towards the lens to open the battery door.
  3. Sony NEX-7 Lens Mount Replacement: step 3, image 1 of 1
    • With the battery door open, push the blue lever in the battery compartment to release the battery.
  4. Sony NEX-7 Lens Mount Replacement, SD card: step 4, image 1 of 1
    • To the left of the battery compartment, the SD card needs to be pushed down slightly with your fingers, which will cause the card to eject.
    • Pull the card out with your fingers.
  5. Sony NEX-7 Lens Mount Replacement, Lens: step 5, image 1 of 2 Sony NEX-7 Lens Mount Replacement, Lens: step 5, image 2 of 2
    • First, turn the camera upside down.
    • Press the button located next to silver lens mount and rotate the lens counterclockwise.
    • Pull the lens away from the camera body.
    • After removing the lens, replace the lens or attach the body cap as soon as possible to prevent damage to the shutter.
  6. Sony NEX-7 Lens Mount Replacement, Lens Mount: step 6, image 1 of 1
    • With the front of the camera facing you, remove the four silver #00 Phillips screws from the metal lens mount.
  7. Sony NEX-7 Lens Mount Replacement: step 7, image 1 of 1
    • Remove these three layers from the lens mount with your finger or by turning the camera face down.
  8. Sony NEX-7 Lens Mount Replacement: step 8, image 1 of 1
    • Remove the two newly visible #00 screws within the metal ring.
  9. Sony NEX-7 Lens Mount Replacement: step 9, image 1 of 1
    • Remove the final metal ring from the mount.
5 other people completed this guide.
Jay Miley
5,375 Reputation
13 Guides authored
Cal Poly, Team 10-55, Amido Spring 2014 Member of Cal Poly, Team 10-55, Amido Spring 2014
CPSU-AMIDO-S14S10G55
4 Members
37 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 41
All Time: 2,741
