Sony NWZ-E473 Screen Replacement
  1. Sony NWZ-E473  Screen Replacement, Back Panel: step 1, image 1 of 1
    • Use a Phillips #00 screwdriver to unscrew the two 5 mm screws located on the bottom of the back of the device.
  2. Sony NWZ-E473  Screen Replacement: step 2, image 1 of 1
    • Use a plastic opening tool to loosen the bottom portion of device.
  3. Sony NWZ-E473  Screen Replacement: step 3, image 1 of 1
    • Use a plastic opening tool to loosen the top panel of the device.
  4. Sony NWZ-E473  Screen Replacement: step 4, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the two 3 mm screws located on the portion under the top panel of the device.
  5. Sony NWZ-E473  Screen Replacement: step 5, image 1 of 3 Sony NWZ-E473  Screen Replacement: step 5, image 2 of 3 Sony NWZ-E473  Screen Replacement: step 5, image 3 of 3
    • Remove the back plate from the device.
  6. Sony NWZ-E473  Screen Replacement, Screen: step 6, image 1 of 1
    Tool used on this step:
    Buy
    • Use a nylon spudger or tweezers to remove the plastic USB cover.
  7. Sony NWZ-E473  Screen Replacement: step 7, image 1 of 1
    • Use a Phillips #00 screwdriver to unscrew two 2 mm screws located on the top corners of the device.
  8. Sony NWZ-E473  Screen Replacement: step 8, image 1 of 1
    • Use a nylon spudger or tweezers to remove the plastic protective plate at the top of device.
  9. Sony NWZ-E473  Screen Replacement: step 9, image 1 of 2 Sony NWZ-E473  Screen Replacement: step 9, image 2 of 2
    • Remove the plastic protective frame located over the motherboard with tweezers and a spudger.
  10. Sony NWZ-E473  Screen Replacement: step 10, image 1 of 1
    • Remove screen connection from motherboard using tweezers and spudger.
  11. Sony NWZ-E473  Screen Replacement: step 11, image 1 of 1
    • Use a Phillips #00 screwdriver to remove two 3 mm screws at the bottom sides and two 1 mm screws at top sides of the device.
  12. Sony NWZ-E473  Screen Replacement: step 12, image 1 of 2 Sony NWZ-E473  Screen Replacement: step 12, image 2 of 2
    • Use a Phillips #00 screwdriver to unscrew two 2 mm screws, and remove the motherboard from the device with tweezers and a plastic opening tool.
  13. Sony NWZ-E473  Screen Replacement: step 13, image 1 of 2 Sony NWZ-E473  Screen Replacement: step 13, image 2 of 2
    • Disconnect the metal shielding plate from the front panel with tweezers or a plastic opening tool.
  14. Sony NWZ-E473  Screen Replacement: step 14, image 1 of 2 Sony NWZ-E473  Screen Replacement: step 14, image 2 of 2
    • Use a plastic opening tool to remove the screen from metal back plate.
Matthew Hintz
330 Reputation
3 Guides authored
USF Tampa, Team 17-6, Watkins Winter 2015 Member of USF Tampa, Team 17-6, Watkins Winter 2015
USFT-WATKINS-W15S17G6
4 Members
7 Guides authored
1 Guide Comment
very helpful!!! thx
Stefan Taubert - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 1,146
