Sony NWZ-E473 Audio Jack Replacement
  1. Sony NWZ-E473 Audio Jack Replacement, Back Panel: step 1, image 1 of 1
    • Use a Phillips #00 screwdriver to unscrew the two 5 mm screws located on the bottom of the back of the device.
  2. Sony NWZ-E473 Audio Jack Replacement: step 2, image 1 of 1
    • Use a plastic opening tool to loosen the bottom portion of device.
  3. Sony NWZ-E473 Audio Jack Replacement: step 3, image 1 of 1
    • Use a plastic opening tool to loosen the top panel of the device.
  4. Sony NWZ-E473 Audio Jack Replacement: step 4, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the two 3 mm screws located on the portion under the top panel of the device.
  5. Sony NWZ-E473 Audio Jack Replacement: step 5, image 1 of 3 Sony NWZ-E473 Audio Jack Replacement: step 5, image 2 of 3 Sony NWZ-E473 Audio Jack Replacement: step 5, image 3 of 3
    • Remove the back plate from the device.
  6. Sony NWZ-E473 Audio Jack Replacement, Audio Jack: step 6, image 1 of 1
    • Unscrew one 2.5 mm screw using a Phillips #00 screwdriver on bottom right portion of device located near audio jack.
  7. Sony NWZ-E473 Audio Jack Replacement: step 7, image 1 of 2 Sony NWZ-E473 Audio Jack Replacement: step 7, image 2 of 2
    • Disconnect the headphone jack connection from the motherboard using any tool to remove black audio piece that needs to be replaced.
Chaz
119 Reputation
1 Guide authored
USF Tampa, Team 17-6, Watkins Winter 2015 Member of USF Tampa, Team 17-6, Watkins Winter 2015
USFT-WATKINS-W15S17G6
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 1,094
