Sony PS-LX300USB Drive Belt Replacement
  1. Sony PS-LX300USB Drive Belt Replacement, Drive Belt: step 1, image 1 of 2 Sony PS-LX300USB Drive Belt Replacement, Drive Belt: step 1, image 2 of 2
    • Lift the rubber mat, and put it to the side. It should be easy to remove, because it simply rests on a metal platter without anything securing it down.
  2. Sony PS-LX300USB Drive Belt Replacement: step 2, image 1 of 1
    • Turn the platter so that the motor pulley can be seen through one of the two outer holes in the platter.
    • If the drive belt is hooked around the motor pulley, unhook it.
    • When reassembling to device, don't forget to hook the new drive belt to the motor pulley.
  3. Sony PS-LX300USB Drive Belt Replacement: step 3, image 1 of 1
    • Grasping the platter by its two inner holes, lift it upwards.
    • Removing the platter may take a small amount of force. If the pulley is unhooked and the tone arm is safely to the side, don’t fear using a small amount of force in lifting the platter.
    • If you haven’t yet unhooked the drive belt, the motor pulley and the belt could sustain damage.
  4. Sony PS-LX300USB Drive Belt Replacement: step 4, image 1 of 2 Sony PS-LX300USB Drive Belt Replacement: step 4, image 2 of 2
    • Peel the drive belt from the inner ridge of the metal platter and put it to the side.
    • Sometimes, the drive belt can fall off the platter during deconstruction. If this is the case, simply take it out of the device wherever it is.
19 other people completed this guide.
Michelle Jakab
633 Reputation
1 Guide authored
Cal Poly, Team S8-G3, Banghart Fall 2017 Member of Cal Poly, Team S8-G3, Banghart Fall 2017
CPSU-BANGHART-F17S8G3
5 Members
5 Guides authored
3 Guide Comments
Thank you for posting!
Jeanine Haven - Reply Share
Thank you for posting this! My belt slipped and I could not figure this out thanks to you I saw how simple a process the repair. Many times thank you
Thank you for this post. I freaked out when belt became detached. I had moved turntable several times to resolve a connection issue and OOPS! Very concise instructions with clear pictures. Awesome!!
Eric Doner - Reply Share
Past 24 Hours: 3
Past 7 Days: 26
Past 30 Days: 152
All Time: 20,181
