Sony PS1100 Needle Cartridge Replacement
  1. Sony PS1100 Needle Cartridge Replacement, Remove the existing Cartridge from the player: step 1, image 1 of 3 Sony PS1100 Needle Cartridge Replacement, Remove the existing Cartridge from the player: step 1, image 2 of 3 Sony PS1100 Needle Cartridge Replacement, Remove the existing Cartridge from the player: step 1, image 3 of 3
    • Place the Arm of the record player into the latch to ensure that it does not move during the needle replacement.
    • The arm must be fully locked into place
  2. Sony PS1100 Needle Cartridge Replacement, Remove the existing Cartridge: step 2, image 1 of 1
    • Firmly grip both sides of the cartridge with your thumb and index fingers.
    • CAREFULLY pull the entire cartridge so that it slides out towards the front of the arm holding the needle.
  3. Sony PS1100 Needle Cartridge Replacement, Insert new needle cartridge: step 3, image 1 of 2 Sony PS1100 Needle Cartridge Replacement, Insert new needle cartridge: step 3, image 2 of 2
    • Using the New cartridge (Sony VL-30G) gently slide into the arm of the record player. It will click into place when inserted properly.
    • Be careful not to touch the needle when inserting the cartridge or else you risk breaking the new one.
  4. Sony PS1100 Needle Cartridge Replacement, Test the new needle Cartridge: step 4, image 1 of 1
    • Once the needle clicks into place, test the record player to ensure that the needle works properly.
L Cis
110 Reputation
1 Guide authored
USF Tampa, Team 1-8, Donnelly Fall 2014 Member of USF Tampa, Team 1-8, Donnelly Fall 2014
USFT-DONNELLY-F14S1G8
1 Member
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 33
All Time: 4,691
