Sony PlayStation 3D Display Control Buttons Replacement
  1. Sony PlayStation 3D Display Control Buttons Replacement, Rear Case: step 1, image 1 of 2 Sony PlayStation 3D Display Control Buttons Replacement, Rear Case: step 1, image 2 of 2
    • Remove the base by pushing in the button and sliding out the unit.
  2. Sony PlayStation 3D Display Control Buttons Replacement: step 2, image 1 of 3 Sony PlayStation 3D Display Control Buttons Replacement: step 2, image 2 of 3 Sony PlayStation 3D Display Control Buttons Replacement: step 2, image 3 of 3
    • Remove USB port cover from back plate with a metal spudger.
    • This will prevent the cover from falling under the back plate once it is removed.
  3. Sony PlayStation 3D Display Control Buttons Replacement: step 3, image 1 of 2 Sony PlayStation 3D Display Control Buttons Replacement: step 3, image 2 of 2
    • With the Phillips #02 screwdriver, remove the six 6 mm length x 6 mm head screws from the back plate.
    • With the Phillips #02 screwdriver, remove the ten 6 mm length x 8 mm head screws from the back plate.
    • These screws have different threads and need to be kept separate.
  4. Sony PlayStation 3D Display Control Buttons Replacement: step 4, image 1 of 3 Sony PlayStation 3D Display Control Buttons Replacement: step 4, image 2 of 3 Sony PlayStation 3D Display Control Buttons Replacement: step 4, image 3 of 3
    • Remove back plate with a plastic opening tool by slowing prying around the entire plate.
    • Be gentle to avoid breaking the plastic clips which hold the plate.
    • Once separated the plate easily lifts off.
  5. Sony PlayStation 3D Display Control Buttons Replacement, Control Buttons: step 5, image 1 of 1
    • With the Phillips #01 screwdriver, remove the two 5 mm length x 7 mm head screws from the top and bottom of the control button bar.
  6. Sony PlayStation 3D Display Control Buttons Replacement: step 6, image 1 of 2 Sony PlayStation 3D Display Control Buttons Replacement: step 6, image 2 of 2
    • Detach the control button bar by depressing the small white tab that connects the bar to its wires.
Tia McNaughton
379 Reputation
3 Guides authored
Cal Poly, Team 12-16, Maness Fall 2015 Member of Cal Poly, Team 12-16, Maness Fall 2015
CPSU-MANESS-F15S12G16
4 Members
8 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 8
All Time: 731
