Sony PlayStation 3D Display Side Speakers Replacement
  1. Sony PlayStation 3D Display Side Speakers Replacement, Rear Case: step 1, image 1 of 2 Sony PlayStation 3D Display Side Speakers Replacement, Rear Case: step 1, image 2 of 2
    • Remove the base by pushing in the button and sliding out the unit.
  2. Sony PlayStation 3D Display Side Speakers Replacement: step 2, image 1 of 3 Sony PlayStation 3D Display Side Speakers Replacement: step 2, image 2 of 3 Sony PlayStation 3D Display Side Speakers Replacement: step 2, image 3 of 3
    • Remove USB port cover from back plate with a metal spudger.
    • This will prevent the cover from falling under the back plate once it is removed.
  3. Sony PlayStation 3D Display Side Speakers Replacement: step 3, image 1 of 2 Sony PlayStation 3D Display Side Speakers Replacement: step 3, image 2 of 2
    • With the Phillips #02 screwdriver, remove the six 6 mm length x 6 mm head screws from the back plate.
    • With the Phillips #02 screwdriver, remove the ten 6 mm length x 8 mm head screws from the back plate.
    • These screws have different threads and need to be kept separate.
  4. Sony PlayStation 3D Display Side Speakers Replacement: step 4, image 1 of 3 Sony PlayStation 3D Display Side Speakers Replacement: step 4, image 2 of 3 Sony PlayStation 3D Display Side Speakers Replacement: step 4, image 3 of 3
    • Remove back plate with a plastic opening tool by slowing prying around the entire plate.
    • Be gentle to avoid breaking the plastic clips which hold the plate.
    • Once separated the plate easily lifts off.
  5. Sony PlayStation 3D Display Side Speakers Replacement, Side Speakers: step 5, image 1 of 3 Sony PlayStation 3D Display Side Speakers Replacement, Side Speakers: step 5, image 2 of 3 Sony PlayStation 3D Display Side Speakers Replacement, Side Speakers: step 5, image 3 of 3
    • With the Phillips #01 screwdriver, remove the four 5 mm length x 7 mm head screws from the assembly (two for each side speaker).
  6. Sony PlayStation 3D Display Side Speakers Replacement: step 6, image 1 of 3 Sony PlayStation 3D Display Side Speakers Replacement: step 6, image 2 of 3 Sony PlayStation 3D Display Side Speakers Replacement: step 6, image 3 of 3
    • Remove the plastic plate covering the speaker.
    • When reassembling, make sure the arrow on the plastic plate is facing up.
    • Lift the speaker out of its holding tray.
  7. Sony PlayStation 3D Display Side Speakers Replacement: step 7, image 1 of 2 Sony PlayStation 3D Display Side Speakers Replacement: step 7, image 2 of 2
    • Remove the speaker by depressing the white tab on the speaker wire connector.
3 other people completed this guide.
viharim
200 Reputation
1 Guide authored
Cal Poly, Team 12-16, Maness Fall 2015 Member of Cal Poly, Team 12-16, Maness Fall 2015
CPSU-MANESS-F15S12G16
4 Members
8 Guides authored
One Comment
Speakers in this page are out of stock, do you think these will work? https://www.amazon.com/Speaker-Speakers-...
Ferserk - Reply
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 30
All Time: 2,593
