Sony Playstation 2 SCPH-79002 - Front Cover Replacement
  1. Sony Playstation 2 SCPH-79002 - Front Cover Replacement, Flip over your system: step 1, image 1 of 1
    • Flip your machine over to the back.
  2. Sony Playstation 2 SCPH-79002 - Front Cover Replacement, Take off the tabs: step 2, image 1 of 1
    • You'll see some outlined grey tabs on the outline of the back, get a spudger or something flat to pop them off.
  3. Sony Playstation 2 SCPH-79002 - Front Cover Replacement, Warranty Sticker: step 3, image 1 of 1
    • There is a warranty sticker on the bottom that shows a tab, peeling it off will VOID your warranty.
  4. Sony Playstation 2 SCPH-79002 - Front Cover Replacement, Unscrewing: step 4, image 1 of 1
    • When you take off all the tabs, there should be a Phillip Head screw under each tab, unscrew them.
  5. Sony Playstation 2 SCPH-79002 - Front Cover Replacement, Taking off the front cover: step 5, image 1 of 2 Sony Playstation 2 SCPH-79002 - Front Cover Replacement, Taking off the front cover: step 5, image 2 of 2
    • Once you have unscrew them, gently take off the front cover of the Playstation 2.
  6. Sony Playstation 2 SCPH-79002 - Front Cover Replacement, Double check you took off the front cover correctly: step 6, image 1 of 1
    • You should now see something like this.
  7. Sony Playstation 2 SCPH-79002 - Front Cover Replacement, Get your replacement front cover: step 7, image 1 of 1
    • Get your replacement front cover and prepare to put it back on.
  8. Sony Playstation 2 SCPH-79002 - Front Cover Replacement, Clipping: step 8, image 1 of 1
    • Align the front cover and put the front cover firstly on the selected area.
  9. Sony Playstation 2 SCPH-79002 - Front Cover Replacement, Clipping: step 9, image 1 of 1
    • Make sure you clip the front cover onto the marked areas.
  10. Sony Playstation 2 SCPH-79002 - Front Cover Replacement, Screwing the screws: step 10, image 1 of 1
    • Put the screws in their correct place and screw them into the Playstation 2.
  11. Sony Playstation 2 SCPH-79002 - Front Cover Replacement, Putting the tabs into their right place: step 11, image 1 of 1
    • When done screwing, put the tabs into their correct places.
You have now put a new front cover onto your Playstation 2 superslim!
Zach luc
566 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 45
All Time: 3,681
