Sony RMT-D197A Battery Contactor Repair
  1. Sony RMT-D197A Battery Contactor Repair, Sony RMT-D197A Battery Contactor Repair: step 1, image 1 of 2 Sony RMT-D197A Battery Contactor Repair, Sony RMT-D197A Battery Contactor Repair: step 1, image 2 of 2
    • Place the remote on a solid, sturdy surface.
    • Use a putty knife to gently pry open the remote.
  2. Sony RMT-D197A Battery Contactor Repair: step 2, image 1 of 2 Sony RMT-D197A Battery Contactor Repair: step 2, image 2 of 2
    • Remove the front panel from the remote.
  3. Sony RMT-D197A Battery Contactor Repair: step 3, image 1 of 1
    • Wear safety glasses and use caution when handling a hot soldering iron.
    • Use the soldering iron to gently desolder the damaged battery contactor.
    • Keep in mind the battery contactor can easily break so make sure to be gentle with the soldering iron.
  4. Sony RMT-D197A Battery Contactor Repair: step 4, image 1 of 2 Sony RMT-D197A Battery Contactor Repair: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Use a pair of tweezers to remove the spring from the contactor.
  5. Sony RMT-D197A Battery Contactor Repair: step 5, image 1 of 1
    • Use the soldering iron to melt solder onto the empty hole.
    • Make sure to accurately place the spring into the correct position.
  6. Sony RMT-D197A Battery Contactor Repair: step 6, image 1 of 2 Sony RMT-D197A Battery Contactor Repair: step 6, image 2 of 2
    • Reattach the two halves of the remote.
  7. Sony RMT-D197A Battery Contactor Repair: step 7, image 1 of 1
    • Insert batteries and try out your remote.
Finish Line
3 other people completed this guide.
Ahmed Sultan
193 Reputation
1 Guide authored
One Comment
As the remote is already disassembled, I took the opportunity to clean the contacts for all the buttons using alcohol.
Jason Lee - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 442
