Sony Reader Touch Edition PRS-600 Battery Replacement
  1. Sony Reader Touch Edition PRS-600 Battery Replacement, Back Panel: step 1, image 1 of 1
    • Using the Phillips head screwdriver PH000, remove the two 1.4 mm screws that are located on the backside of the device.
  2. Sony Reader Touch Edition PRS-600 Battery Replacement: step 2, image 1 of 1
    • Slide the back cover off by pushing it to the left, away from the side that held the screws.
    • Remove the cover.
  3. Sony Reader Touch Edition PRS-600 Battery Replacement: step 3, image 1 of 1
    • This is what the device should look like once the back cover panel has been removed.
  4. Sony Reader Touch Edition PRS-600 Battery Replacement, Battery: step 4, image 1 of 1
    • Once the back cover has been removed locate the battery in the bottom right corner of the device.
    • Using the pointed end of the spudger, push out the white plug that is connected to the battery from its beige base.
  5. Sony Reader Touch Edition PRS-600 Battery Replacement: step 5, image 1 of 1
    • Use the flat end of the spudger to pry the battery out of its holder. There may be glue holding it in place.
8 other people completed this guide.
Terrika Ngobili
857 Reputation
7 Guides authored
Clemson, Team 1-4, Benson Fall 2014 Member of Clemson, Team 1-4, Benson Fall 2014
CLEM-BENSON-F14S1G4
4 Members
22 Guides authored
2 Comments
It works great - thanks very much for this guide!
kitimatwoz - Reply
where can i buy the battery for replacement ?? what battery is ? Answer me pls on: edgarjacob16@gmail.com
Edgar Jacob - Reply
Past 24 Hours: 3
Past 7 Days: 8
Past 30 Days: 60
All Time: 4,802
