Introduction
Identification
This lens can be identified by the markings “E 4.5-6.3/55-210 OSS” in addition to the model/serial number sticker.
Additional Links
Gently disconnect cable from ZIP connector.
Remove E-mount bezel.
Gently disconnect three cables from ZIP connector.
The two wider connectors open from the cable side, the thinner connector opens from the back side.
Remove two screws from lens park sensor.
Remove lens park sensor.
Remove three screws.
Pull lens out of external encasement.
Maneuver the telescope sensor so that it unmates from the slot in the internal lens body
Carefully feed the OSS/AF motor wire through the slot.
Remove three screws from the aperture end of the telescoping mechanism.
Lift lens to reveal and remove three brass/nylon nuts.
Remove three screws from the slide guides on the aperture end of the lens.
Remove three black nylon slide washers from the lens encasement.
Remove the OSS/AF mechanism.
Gently pull the cable up and out from the lens encasement groove.
Remove Kapton tape from aperture motor connector.
Disconnect aperture connector.
Remove two screws from aperture ring.
Remove aperture mechanism.
Disconnect three cables.
Remove three screws
Gently separate the OSS mechanism.
6 other people completed this guide.
5 Guide Comments
why did you need to dissasemble this lens. this lens looks similar to my 55mm lens which no longer focuses and the camera doesn’t recognize the lense anymore.
I need to know maddly, how can I have a reposition of the 6 spring there are on the first lense.
Is there any way?
If not, can you tell me specificcaly the size and the strength?
To remove the flat cables theres a little trigger (im my case in grey) that opens up inversely to the cable that let you take the cables out, I pushed mines and they´re working but don´t do it like I did, it can ruin your lens, mine is now up and running.
I did it to clean the lens but most of the dust is in the front glass witch you have to rip the little plastic that is fixing it in place, de dual lens front glass is not supposed to be open but thats the way!
This guide is great, just try to remember where all the screw came of and dived them into jars, the black ones are all the same!
good luck to everyone!
Kann man die Frontlinse auch abmontieren ohne das Objektiv von der E-Mount-Seite her zu demontieren?
Yes, the nameplate is able to be popped off revealing three screws underneath it. This allows you to remove the front lens element. Here's a couple of YouTube videos I found that shows you the process:
[Deutsche Übersetzung]: Ja, das Typenschild lässt sich abnehmen und gibt drei darunterliegende Schrauben frei. Dadurch kann das vordere Linsenelement entfernt werden. Hier sind ein paar YouTube-Videos, die den Vorgang zeigen:
https://www.youtube.com/watch?v=YGRoaHwt...
