Sony SRS-X3 Battery Charging Port Replacement
  1. Sony SRS-X3 Battery Charging Port Replacement, Battery Charging Port: step 1, image 1 of 1
    • Remove the 6 10mm Philips head screws shown, using a PH1 screwdriver
  2. Sony SRS-X3 Battery Charging Port Replacement: step 2, image 1 of 1
    • Remove the 5 8mm Philips head screws shown. These are holding the battery and the green circuit board in.
  3. Sony SRS-X3 Battery Charging Port Replacement: step 3, image 1 of 1
    • Lift the battery pack and circuit board out of the housing and locate the wires and ribbon connector shown in the figure.
  4. Sony SRS-X3 Battery Charging Port Replacement: step 4, image 1 of 2 Sony SRS-X3 Battery Charging Port Replacement: step 4, image 2 of 2
    • Remove the ribbon connector and the connector from the battery pack (Note: These connectors are not easy to remove. Force may be necessary but the connectors are durable)
    • After the connections are remove you are free to replace the circuit board.
5 other people completed this guide.
11 Comments
Bradley, this is a SONY 40BKB537U-CNF2G board….where can I get one? The mini charge port is bad on mine and v difficult to replace.
Thanks
michael ruse - Reply
Where can I buy the whole circuit board to replace the Charging port
Sony Mini speaker SRS - X3
40BKB537U - CNF2G
charging port
Morgan -
Where can I buy circuit board To replace charging port Sony Mini speaker SRS - X3
40BKB537U-CNF2G
Morgan -
Hi Michael, did you find a replacement board? I need to replace mine as well.
Julie Miller -
I have all the part of this speaker. Email me to negotiate! Kennyportillo99@gmail.com
kennycontreras44 -
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 38
All Time: 6,753
