Sony SRS-X3 Motherboard Replacement
  1. Sony SRS-X3 Motherboard Replacement, Speakers: step 1, image 1 of 1
    • Remove the rubber feet on the bottom of the device.
  2. Sony SRS-X3 Motherboard Replacement: step 2, image 1 of 1
    • Remove the 6 silver screws with a Phillips #1 screwdriver.
    • Remove the bottom plastic cover of speaker.
  3. Sony SRS-X3 Motherboard Replacement: step 3, image 1 of 1
    • Remove the two screws holding the battery pack with the Phillips #1 screwdriver.
    • Remove the battery back with a spudger.
  4. Sony SRS-X3 Motherboard Replacement: step 4, image 1 of 1
    • Remove the three screws using a Phillips #1 screwdriver.
    • Remove the green circuit board and the battery pack.
    • The battery pack and green circuit board will still be connected to the speaker by a ribbon wire.
  5. Sony SRS-X3 Motherboard Replacement: step 5, image 1 of 2 Sony SRS-X3 Motherboard Replacement: step 5, image 2 of 2
    • Pop off the front speaker face (dark grey with little holes) by pushing out 3 tabs where screws were previously located and sticking the spudger in the crack where grey speaker face meets the outer shell.
    • You may really have to pry on this part; it is not easy to remove and will pop out when released.
  6. Sony SRS-X3 Motherboard Replacement: step 6, image 1 of 1
    • Remove the eight black screws with a Phillips #1 screwdriver.
  7. Sony SRS-X3 Motherboard Replacement: step 7, image 1 of 2 Sony SRS-X3 Motherboard Replacement: step 7, image 2 of 2
    • Remove the front face by prying the two black tabs using a spudger.
    • This face is glued in and may need some elbow grease to remove. Don't worry about breaking anything, as it is all connected.
  8. Sony SRS-X3 Motherboard Replacement: step 8, image 1 of 2 Sony SRS-X3 Motherboard Replacement: step 8, image 2 of 2
    • Remove the speaker wires from each speaker (2 wires per speaker) and take the speakers out of the device.
    • The speaker wire connectors are made to connect very snug, so they should be hard to remove. Give it a good tug and they should pop off the male end.
    • Remove the speakers from the device.
  9. Sony SRS-X3 Motherboard Replacement, Motherboard: step 9, image 1 of 3 Sony SRS-X3 Motherboard Replacement, Motherboard: step 9, image 2 of 3 Sony SRS-X3 Motherboard Replacement, Motherboard: step 9, image 3 of 3
    • Remove the ribbon wire simply by pulling it out of the fixture in which it connects. Once removed, sit the small green board to the side and prepare to remove the Motherboard.
  10. Sony SRS-X3 Motherboard Replacement: step 10, image 1 of 1
    • Locate the Motherboard through the hole in which the battery pack normally rests.
  11. Sony SRS-X3 Motherboard Replacement: step 11, image 1 of 1
    • Use your fingers to pull the board upwards while the speakers top is facing downwards. In doing so, use more force than you are comfortable with. (Do NOT worry. The board slides upwards, regardless of the friction that may seem like it is keeping it from sliding out.)
  12. Sony SRS-X3 Motherboard Replacement: step 12, image 1 of 3 Sony SRS-X3 Motherboard Replacement: step 12, image 2 of 3 Sony SRS-X3 Motherboard Replacement: step 12, image 3 of 3
    • Once the Motherboard has been removed, you are free to remove all of the wires that are connected to it. Gently pull on the clips where the wires insert into the board to remove all of the wires.
Zachary Church
101 Reputation
1 Guide authored
6 Comments
hello I want the power board to buy where can I get that to buy
oxco - Reply
Are you still looking for it. I have one. We can negotiate!!
kennycontreras44 -
Do you still have the circuit board 40BKB537U-CNF2G for the Sony SRS X3?
reeree726 - Reply
need a 40BKB537U-CNF2G board, how much shipped to Tucson AZ?
michael ruse - Reply
The charge port (mini usb I think) is broken on sony srs-x3
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 25
All Time: 2,948
