Sony SRS-X5 Button Pad Replacement
  1. Sony SRS-X5 Button Pad Replacement, Battery: step 1, image 1 of 1
    • To gain access to the 6 bottom screws remove the following. Remove the adhered 4 corner foam pads on the bottom of the speaker using the blue plastic opening tool to reveal the screws underneath. Remove the adhered 2 center plastic squares.
    • Make sure the speaker is unplugged and powered down before doing any work on the device.
  2. Sony SRS-X5 Button Pad Replacement: step 2, image 1 of 2 Sony SRS-X5 Button Pad Replacement: step 2, image 2 of 2
    • Unscrew the six 6mm screws with a Phillips head #1 screwdriver.
    • Remove the bottom panel of the speaker.
  3. Sony SRS-X5 Button Pad Replacement: step 3, image 1 of 1
    • Unplug the battery by gently pinching the plastic end connected to the smaller board and pull away.
    • Remove the battery.
  4. Sony SRS-X5 Button Pad Replacement, Speaker: step 4, image 1 of 1
    • To remove the speaker grill, first push down slightly on the 2 plastic hook tabs to release them, then push the middle plastic screw tab out.
  5. Sony SRS-X5 Button Pad Replacement: step 5, image 1 of 1
    • Remove the eight 0.5mm Phillips #1 screws from the speaker panel.
  6. Sony SRS-X5 Button Pad Replacement: step 6, image 1 of 2 Sony SRS-X5 Button Pad Replacement: step 6, image 2 of 2
    • Using the plastic opening tool, flip open the speaker panel.
  7. Sony SRS-X5 Button Pad Replacement: step 7, image 1 of 3 Sony SRS-X5 Button Pad Replacement: step 7, image 2 of 3 Sony SRS-X5 Button Pad Replacement: step 7, image 3 of 3
    • Unplug the 6-pin speaker connector and 2-pin microphone connector from the motherboard by squeezing the sides of the plastic ends.
  8. Sony SRS-X5 Button Pad Replacement, Button Pad: step 8, image 1 of 1
    • Unplug the electrical cord from the button pad.
  9. Sony SRS-X5 Button Pad Replacement: step 9, image 1 of 2 Sony SRS-X5 Button Pad Replacement: step 9, image 2 of 2
    • Using both the plastic opening tool and metal spudger gently pry open the cover from the top of the speaker.
  10. Sony SRS-X5 Button Pad Replacement: step 10, image 1 of 1
    • Gently remove the cover using your hands.
    • Make sure you remove the cover gently so it doesn't break.
  11. Sony SRS-X5 Button Pad Replacement: step 11, image 1 of 2 Sony SRS-X5 Button Pad Replacement: step 11, image 2 of 2
    • Using the Phillips #00, unscrew the three 3.32mm screws keeping the button board in place.
  12. Sony SRS-X5 Button Pad Replacement: step 12, image 1 of 1
    • Gently remove the button pad from the speaker.
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 17
All Time: 1,059
