Sony SRS-X55 I/O Board Replacement
  1. Sony SRS-X55 I/O Board Replacement, Battery: step 1, image 1 of 3 Sony SRS-X55 I/O Board Replacement, Battery: step 1, image 2 of 3 Sony SRS-X55 I/O Board Replacement, Battery: step 1, image 3 of 3
    • Remove the six screw covers with a spudger.
    • Remove the six 11 mm Phillips screws from the bottom panel.
    • Remove the bottom panel of the speaker.
  2. Sony SRS-X55 I/O Board Replacement: step 2, image 1 of 1
    • Disconnect the battery cable from the motherboard.
    • Remove the battery.
  3. Sony SRS-X55 I/O Board Replacement, I/O Board: step 3, image 1 of 2 Sony SRS-X55 I/O Board Replacement, I/O Board: step 3, image 2 of 2
    • Remove the two Phillips screws from the I/O board.
    • Remove the front panel to the speaker by pushing on the two tabs in the corners.
  4. Sony SRS-X55 I/O Board Replacement: step 4, image 1 of 1
    • Disconnect the ribbon cable from the I/O board.
    • Carefully remove the I/O board from the speaker.
One Comment
Where can i get a new i/o board?
Kyle Workman - Reply
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 21
All Time: 2,393
