Sony SRS-X55 Motherboard Replacement
  1. Sony SRS-X55 Motherboard Replacement, Battery: step 1, image 1 of 3 Sony SRS-X55 Motherboard Replacement, Battery: step 1, image 2 of 3 Sony SRS-X55 Motherboard Replacement, Battery: step 1, image 3 of 3
    • Remove the six screw covers with a spudger.
    • Remove the six 11 mm Phillips screws from the bottom panel.
    • Remove the bottom panel of the speaker.
  2. Sony SRS-X55 Motherboard Replacement: step 2, image 1 of 1
    • Disconnect the battery cable from the motherboard.
    • Remove the battery.
  3. Sony SRS-X55 Motherboard Replacement, Speaker Panel: step 3, image 1 of 1
    • Remove the speaker grill by pushing on the two tabs in the corners.
  4. Sony SRS-X55 Motherboard Replacement: step 4, image 1 of 1
    • Remove the eight 0.5mm Phillips #1 screws from the speaker panel.
  5. Sony SRS-X55 Motherboard Replacement, Motherboard: step 5, image 1 of 3 Sony SRS-X55 Motherboard Replacement, Motherboard: step 5, image 2 of 3 Sony SRS-X55 Motherboard Replacement, Motherboard: step 5, image 3 of 3
    • Flip open the speaker panel to access the interior of the device.
    • Carefully unplug the three cables and one ribbon connector connected to the motherboard.
    • Remove the motherboard.
Jordon McDuffie
101 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 25
All Time: 3,235
