Sony SRS-X55 Speaker Reverberator Replacement
  1. Sony SRS-X55 Speaker Reverberator Replacement, Speaker Reverberator: step 1, image 1 of 1
    • Locate the six 9 mm screws on the bottom of the speaker and remove them using Phillips head #2.
  2. Sony SRS-X55 Speaker Reverberator Replacement: step 2, image 1 of 2 Sony SRS-X55 Speaker Reverberator Replacement: step 2, image 2 of 2
    • Insert a plastic spudger into the seam on the bottom panel and lift it away from the rest of the speaker.
  3. Sony SRS-X55 Speaker Reverberator Replacement: step 3, image 1 of 3 Sony SRS-X55 Speaker Reverberator Replacement: step 3, image 2 of 3 Sony SRS-X55 Speaker Reverberator Replacement: step 3, image 3 of 3
    Tool used on this step:
    Buy
    • Locate the battery connection and unplug it using a pair of metal tweezers.
  4. Sony SRS-X55 Speaker Reverberator Replacement: step 4, image 1 of 2 Sony SRS-X55 Speaker Reverberator Replacement: step 4, image 2 of 2
    • Locate the remaining two 3.5 mm screws on the bottom of the I/O board and remove them using a Phillips head #2 screwdriver.
  5. Sony SRS-X55 Speaker Reverberator Replacement: step 5, image 1 of 1
    • Remove the I/O board from the rest of the speaker. A plastic spudger can aid in this process if it is inserted into the edge as shown and gently pried.
  6. Sony SRS-X55 Speaker Reverberator Replacement: step 6, image 1 of 2 Sony SRS-X55 Speaker Reverberator Replacement: step 6, image 2 of 2
    • Insert a plastic spudger into the seam where the forward facing metal speaker cover meets the speaker body and gently pry it upward until it releases.
  7. Sony SRS-X55 Speaker Reverberator Replacement: step 7, image 1 of 2 Sony SRS-X55 Speaker Reverberator Replacement: step 7, image 2 of 2
    • Locate the eight 8.9 mm screws on the face of the speaker assembly and remove them using a Phillips head #2 screwdriver.
  8. Sony SRS-X55 Speaker Reverberator Replacement: step 8, image 1 of 2 Sony SRS-X55 Speaker Reverberator Replacement: step 8, image 2 of 2
    • Insert a plastic spudger underneath one of the tabs on the front of the speaker assembly and gently raise it.
    • Continue to the next step before attempting to lift the speaker assembly entirely away from the rest of the speaker to avoid damaging internal wire connections.
  9. Sony SRS-X55 Speaker Reverberator Replacement: step 9, image 1 of 3 Sony SRS-X55 Speaker Reverberator Replacement: step 9, image 2 of 3 Sony SRS-X55 Speaker Reverberator Replacement: step 9, image 3 of 3
    • Locate the two wire connections as shown underneath of the speaker assembly and unplug them using a pair of tweezers.
    • Lift the speaker assembly away.
  10. Sony SRS-X55 Speaker Reverberator Replacement: step 10, image 1 of 2 Sony SRS-X55 Speaker Reverberator Replacement: step 10, image 2 of 2
    • Locate the eight 7.5 mm screws across both of the speaker reverberators and remove them using a Phillips head #2 screwdriver.
    • Lift the speaker reverberators away and replace them.
2 other people completed this guide.
Eric Coletto
113 Reputation
1 Guide authored
IUPUI, Team 2-3, Baechle Spring 2017 Member of IUPUI, Team 2-3, Baechle Spring 2017
IUPUI-BAECHLE-S17S2G3
3 Members
3 Guides authored
One Comment
Nice Guide, but do you know the exact speaker size and/or type?
I can not find the exact speakers.
THX
Elduderino79
El Duderino - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 1,527
