Sony SRS-XB40 LED Control Panel Replacement
  1. Sony SRS-XB40 LED Control Panel Replacement, Speaker Assembly Replacement: step 1, image 1 of 1
    • Remove the speaker case from the outer casing by prying it from the base of the speaker using a metal spudger.
  2. Sony SRS-XB40 LED Control Panel Replacement: step 2, image 1 of 1
    • Remove the four T-8 screws (15 mm long) from the black speaker face.
  3. Sony SRS-XB40 LED Control Panel Replacement: step 3, image 1 of 1
    • Pry the two rubber end pieces loose enough to pry off two pieces of the long plastic casing from the speaker body using a metal spudger.
  4. Sony SRS-XB40 LED Control Panel Replacement: step 4, image 1 of 1
    • Pry the two remaining rubber pieces of the casing completely away from the body of the speaker with the same metal pry tool.
  5. Sony SRS-XB40 LED Control Panel Replacement: step 5, image 1 of 2 Sony SRS-XB40 LED Control Panel Replacement: step 5, image 2 of 2
    • Once you have removed the outer blue casing, four T-8 screws (15 mm long) will be revealed on each corner. After removing these screws, simply pull the top part of the speaker way from the body to get the the inner part of the speaker.
  6. Sony SRS-XB40 LED Control Panel Replacement: step 6, image 1 of 1
    • Once you have gotten to the internal parts of the speaker, there are seven wires connecting the speaker plate to the body of the speaker. Pinch the release tabs at the top of each of the four main wires to remove them.
  7. Sony SRS-XB40 LED Control Panel Replacement: step 7, image 1 of 3 Sony SRS-XB40 LED Control Panel Replacement: step 7, image 2 of 3 Sony SRS-XB40 LED Control Panel Replacement: step 7, image 3 of 3
    • Simply pull the thin wires on each side to remove them from their attachment points.
    • Remove the final red and black wire by gently pulling it apart.
    • This will ultimately detach the speaker plate from the base.
  8. Sony SRS-XB40 LED Control Panel Replacement, LED Control Panel: step 8, image 1 of 2 Sony SRS-XB40 LED Control Panel Replacement, LED Control Panel: step 8, image 2 of 2
    • After you take the speaker plate off the body of the speaker, locate the LED control panels on each end of the speaker plate.
  9. Sony SRS-XB40 LED Control Panel Replacement: step 9, image 1 of 1
    • Unscrew the 10mm PH1 screw from each control panel.
    • The green panel should now be loose and connected only by the red and black plug in.
  10. Sony SRS-XB40 LED Control Panel Replacement: step 10, image 1 of 1
    • Carefully unplug the wire from the panel, releasing the panel from the speaker plate.
  11. Sony SRS-XB40 LED Control Panel Replacement: step 11, image 1 of 1
    • Your LED light control panel is now disassembled and ready to replace.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 12
All Time: 1,086
