Sony SRS-XB43 Speaker Replacement
  1. Sony SRS-XB43 Speaker Replacement, Faceplate: step 1, image 1 of 2 Sony SRS-XB43 Speaker Replacement, Faceplate: step 1, image 2 of 2
    • Insert the metal spudger into the mesh's seam/opening located at the bottom of the speaker.
    • Begin applying pressure, prying along the run of the seam until the mesh cover begins to come loose.
    • Fully open the hinged mesh cover and pry it off the unit.
  2. Sony SRS-XB43 Speaker Replacement: step 2, image 1 of 1
    • Turn the speaker so the back is facing you.
    • Remove the factory tamper seal below the speaker volume toggle to reveal a single screw.
    • Remove the single screw using a T8 Torx.
  3. Sony SRS-XB43 Speaker Replacement: step 3, image 1 of 1
    • Remove all ten screws using a Phillips #1 screwdriver.
  4. Sony SRS-XB43 Speaker Replacement: step 4, image 1 of 2 Sony SRS-XB43 Speaker Replacement: step 4, image 2 of 2
    • Slowly lift the speaker face off of the housing unit.
    • Unplug the six wires connecting the faceplate to the motherboard.
  5. Sony SRS-XB43 Speaker Replacement, Speaker: step 5, image 1 of 3 Sony SRS-XB43 Speaker Replacement, Speaker: step 5, image 2 of 3 Sony SRS-XB43 Speaker Replacement, Speaker: step 5, image 3 of 3
    • On the face plate of the speaker, locate the black ribbon cable plugged into the green circuit board to your right.
    • Grab the ribbon cable from its base and apply a light verticle force upwards to unplug it from the PCB.
    • This step prevents the cable from getting in the way of the right speaker as it is being removed.
  6. Sony SRS-XB43 Speaker Replacement: step 6, image 1 of 1
    • Remove eight black 10 mm screws attached to the speaker plate using a Phillips #1 screwdriver.
  7. Sony SRS-XB43 Speaker Replacement: step 7, image 1 of 2 Sony SRS-XB43 Speaker Replacement: step 7, image 2 of 2
    • Remove the two individual speakers.
Bishoy Mikhail
253 Reputation
2 Guides authored
UMass Dartmouth, Team 3-5, Botvin Fall 2022 Member of UMass Dartmouth, Team 3-5, Botvin Fall 2022
UMASSD-BOTVIN-F22S3G5
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 15
Past 30 Days: 53
All Time: 991
