Sony SS-CCP1 Speaker Replacement
  1. Sony SS-CCP1 Speaker Replacement, Screen: step 1, image 1 of 3 Sony SS-CCP1 Speaker Replacement, Screen: step 1, image 2 of 3 Sony SS-CCP1 Speaker Replacement, Screen: step 1, image 3 of 3
    • Pull screen cover from the edges for removal. This will not require much effort.
  2. Sony SS-CCP1 Speaker Replacement, Speaker: step 2, image 1 of 2 Sony SS-CCP1 Speaker Replacement, Speaker: step 2, image 2 of 2
    • Remove the seven 18.06mm PH1 screws.
  3. Sony SS-CCP1 Speaker Replacement: step 3, image 1 of 3 Sony SS-CCP1 Speaker Replacement: step 3, image 2 of 3 Sony SS-CCP1 Speaker Replacement: step 3, image 3 of 3
    • Remove the crimps from the tweeter speaker.
    • If its not connected too tightly the crimps can be removed by hand pressure only.
    • If its too tight to be removed by hand, then you can use a pair of pliers to removed the crimps.
    • Never remove by pulling on the cables. Always pull by the metal crimps.
  4. Sony SS-CCP1 Speaker Replacement: step 4, image 1 of 3 Sony SS-CCP1 Speaker Replacement: step 4, image 2 of 3 Sony SS-CCP1 Speaker Replacement: step 4, image 3 of 3
    • Remove the crimps from the 12cm loudspeaker.
  5. Sony SS-CCP1 Speaker Replacement: step 5, image 1 of 2 Sony SS-CCP1 Speaker Replacement: step 5, image 2 of 2
    • Remove the grommet using an object with a flat edge.
    • The grommet is not made of rubber, it is made of plastic. Be careful when removing it, as it can break easily.
  6. Sony SS-CCP1 Speaker Replacement: step 6, image 1 of 2 Sony SS-CCP1 Speaker Replacement: step 6, image 2 of 2
    • Feed the speaker cable through the front of the box.
4 other people completed this guide.
Dallas
892 Reputation
3 Guides authored
IUPUI, Team 3-2, Baechle Fall 2016 Member of IUPUI, Team 3-2, Baechle Fall 2016
IUPUI-BAECHLE-F16S3G2
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 32
All Time: 3,913
