Sony UBP-UX80 Bluetooth Card Replacement
  1. Sony UBP-UX80 Bluetooth Card Replacement, Top Cover: step 1, image 1 of 3 Sony UBP-UX80 Bluetooth Card Replacement, Top Cover: step 1, image 2 of 3 Sony UBP-UX80 Bluetooth Card Replacement, Top Cover: step 1, image 3 of 3
    • Use a Phillips #2 screwdriver to remove the two 10.5 mm screws that secure the two side panels onto the back of the player.
    • Slide both covers back about a 1/2 inch, then pull them away from the case.
  2. Sony UBP-UX80 Bluetooth Card Replacement: step 2, image 1 of 3 Sony UBP-UX80 Bluetooth Card Replacement: step 2, image 2 of 3 Sony UBP-UX80 Bluetooth Card Replacement: step 2, image 3 of 3
    • Use a Phillips #2 screwdriver to remove the two 10.5 mm screws on the side of the case, each connecting to a tab on the cover.
    • Similar to the previous step, it is identical cases on both sides of the device.
    • Use a Phillips #2 screwdriver to remove the two 10.5 mm screws (one next to the Wi-Fi logo and one next to the Blu-ray logo).
  3. Sony UBP-UX80 Bluetooth Card Replacement: step 3, image 1 of 2 Sony UBP-UX80 Bluetooth Card Replacement: step 3, image 2 of 2
    • Press in the tabs found on the front-sides of the case (connected to the front panel).
    • Slide the top cover forward.
    • Lift off the case.
  4. Sony UBP-UX80 Bluetooth Card Replacement: step 4, image 1 of 3 Sony UBP-UX80 Bluetooth Card Replacement: step 4, image 2 of 3 Sony UBP-UX80 Bluetooth Card Replacement: step 4, image 3 of 3
    • Find the eleven 10.5 mm silver screws and two 6 mm black screws on the perimeter of the silver cover plate.
    • Remove the silver screws using a Phillips #2 screwdriver and the black ones using a Phillips #1 screwdriver.
    • Life the back of the cover up and off of the chasis.
  5. Sony UBP-UX80 Bluetooth Card Replacement, Front Cover: step 5, image 1 of 3 Sony UBP-UX80 Bluetooth Card Replacement, Front Cover: step 5, image 2 of 3 Sony UBP-UX80 Bluetooth Card Replacement, Front Cover: step 5, image 3 of 3
    • Toward the panel there is a ribbon cable with 4 small black pieces of tape holding it down
    • Pull directly up on the ribbon cable to disconnect it from the motherboard
    • Gently pull the cable back away from the motherboard pulling the tape off with it
  6. Sony UBP-UX80 Bluetooth Card Replacement: step 6, image 1 of 1
    • Once all pieces of tape have been pulled up, the ribbon cable should look like this.
  7. Sony UBP-UX80 Bluetooth Card Replacement: step 7, image 1 of 2 Sony UBP-UX80 Bluetooth Card Replacement: step 7, image 2 of 2
    • There are screws on every side of the front panel holding it in. Use a #2 Phillips head screwdriver to remove the nine screws.
    • Unscrew the three 10.5 mm long ph #2 screws on the top.
    • Unscrew the four 10.5 mm long ph #2 screws on the bottom.
  8. Sony UBP-UX80 Bluetooth Card Replacement: step 8, image 1 of 2 Sony UBP-UX80 Bluetooth Card Replacement: step 8, image 2 of 2
    • Use a Phillips #2 screwdriver to remove the 10.5 mm screws, one on each side of the device.
  9. Sony UBP-UX80 Bluetooth Card Replacement: step 9, image 1 of 3 Sony UBP-UX80 Bluetooth Card Replacement: step 9, image 2 of 3 Sony UBP-UX80 Bluetooth Card Replacement: step 9, image 3 of 3
    • Lift tab on the left side of the device
    • Work your way right, lifting the next tabs. One on the bottom and one the Top
    • Continue working the tabs on the top and bottom, keeping them from snapping back in place.
  10. Sony UBP-UX80 Bluetooth Card Replacement: step 10, image 1 of 1
    • Once all tabs are disconnected, pull the front panel forward to fully disconnect it
  11. Sony UBP-UX80 Bluetooth Card Replacement, Bluetooth Card: step 11, image 1 of 1
    • Once you have the front panel removed the Bluetooth card is located on the left side of the device.
  12. Sony UBP-UX80 Bluetooth Card Replacement: step 12, image 1 of 2 Sony UBP-UX80 Bluetooth Card Replacement: step 12, image 2 of 2
    • Gently remove the small brass connection, remove it, being careful not to break the connector or the wire as they are very small.
    • Once the wire has been gently removed, this should be the end result.
  13. Sony UBP-UX80 Bluetooth Card Replacement: step 13, image 1 of 1
    • Remove the single 10.5mm screw securing the card to the chassis using the #2 Phillips head screwdriver.
  14. Sony UBP-UX80 Bluetooth Card Replacement: step 14, image 1 of 1
    • Pull the card away from the chassis to remove it.
Nate Picard
349 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 68
