Sony UBP-UX80 Top Cover Removal
  1. Sony UBP-UX80 Top Cover Removal, Top Cover: step 1, image 1 of 3 Sony UBP-UX80 Top Cover Removal, Top Cover: step 1, image 2 of 3 Sony UBP-UX80 Top Cover Removal, Top Cover: step 1, image 3 of 3
    • Use a Phillips #2 screwdriver to remove the two 10.5 mm screws that secure the two side panels onto the back of the player.
    • Slide both covers back about a 1/2 inch, then pull them away from the case.
  2. Sony UBP-UX80 Top Cover Removal: step 2, image 1 of 3 Sony UBP-UX80 Top Cover Removal: step 2, image 2 of 3 Sony UBP-UX80 Top Cover Removal: step 2, image 3 of 3
    • Use a Phillips #2 screwdriver to remove the two 10.5 mm screws on the side of the case, each connecting to a tab on the cover.
    • Similar to the previous step, it is identical cases on both sides of the device.
    • Use a Phillips #2 screwdriver to remove the two 10.5 mm screws (one next to the Wi-Fi logo and one next to the Blu-ray logo).
  3. Sony UBP-UX80 Top Cover Removal: step 3, image 1 of 2 Sony UBP-UX80 Top Cover Removal: step 3, image 2 of 2
    • Press in the tabs found on the front-sides of the case (connected to the front panel).
    • Slide the top cover forward.
    • Lift off the case.
  4. Sony UBP-UX80 Top Cover Removal: step 4, image 1 of 3 Sony UBP-UX80 Top Cover Removal: step 4, image 2 of 3 Sony UBP-UX80 Top Cover Removal: step 4, image 3 of 3
    • Find the eleven 10.5 mm silver screws and two 6 mm black screws on the perimeter of the silver cover plate.
    • Remove the silver screws using a Phillips #2 screwdriver and the black ones using a Phillips #1 screwdriver.
    • Life the back of the cover up and off of the chasis.
Finish Line
Kenny Young
413 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 81
