Sony VAIO PCG-933A Battery Replacement
  1. Sony VAIO PCG-933A Battery Replacement, Battery: step 1, image 1 of 2 Sony VAIO PCG-933A Battery Replacement, Battery: step 1, image 2 of 2
    • Turn the laptop upside down so that the top is sitting on a flat surface.
    • If you are looking at the bottom of the laptop the battery is located on the front right side of the laptop; the opposite side from the floppy disk drive.
  2. Sony VAIO PCG-933A Battery Replacement: step 2, image 1 of 3 Sony VAIO PCG-933A Battery Replacement: step 2, image 2 of 3 Sony VAIO PCG-933A Battery Replacement: step 2, image 3 of 3
    • As shown by the arrow, slide the plastic cover up and then pull out and downwards.
    • You should now be able to pull the battery out.
Sara Lillard
165 Reputation
8 Guides authored
Cal Poly, Team 12-36, Maness Spring 2011 Member of Cal Poly, Team 12-36, Maness Spring 2011
CPSU-MANESS-S11S12G36
4 Members
16 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 5
All Time: 1,583
