Sony Vaio Fit 13A Back Cover Replacement
  1. Sony Vaio Fit 13A Back Cover Replacement, Back Cover: step 1, image 1 of 2 Sony Vaio Fit 13A Back Cover Replacement, Back Cover: step 1, image 2 of 2
    • Starting with the laptop top-down, locate and remove the twelve 1mm Phillips #0 screws securing the back cover to the main body of the computer.
  2. Sony Vaio Fit 13A Back Cover Replacement: step 2, image 1 of 2 Sony Vaio Fit 13A Back Cover Replacement: step 2, image 2 of 2
    • Use the Plastic Opening Tools or Metal Spudger to carefully loosen back cover from the body of the computer.
    • Be sure to avoid headphone jack when removing back cover by lifting cover away from computer and up.
  3. Sony Vaio Fit 13A Back Cover Replacement: step 3, image 1 of 1
    • Lift off back cover to access inner components of computer.
2 other people completed this guide.
Alex Prange
527 Reputation
3 Guides authored
Cal Poly, Team 21-19, Maness Winter 2015 Member of Cal Poly, Team 21-19, Maness Winter 2015
CPSU-MANESS-W15S21G19
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 20
All Time: 3,724
