Sony Vaio Fit 13A Battery Replacement
  1. Sony Vaio Fit 13A Battery Replacement, Back Cover: step 1, image 1 of 2 Sony Vaio Fit 13A Battery Replacement, Back Cover: step 1, image 2 of 2
    • Starting with the laptop top-down, locate and remove the twelve 1mm Phillips #0 screws securing the back cover to the main body of the computer.
  2. Sony Vaio Fit 13A Battery Replacement: step 2, image 1 of 2 Sony Vaio Fit 13A Battery Replacement: step 2, image 2 of 2
    • Use the Plastic Opening Tools or Metal Spudger to carefully loosen back cover from the body of the computer.
    • Be sure to avoid headphone jack when removing back cover by lifting cover away from computer and up.
  3. Sony Vaio Fit 13A Battery Replacement: step 3, image 1 of 1
    • Lift off back cover to access inner components of computer.
  4. Sony Vaio Fit 13A Battery Replacement, Battery: step 4, image 1 of 2 Sony Vaio Fit 13A Battery Replacement, Battery: step 4, image 2 of 2
    • Locate and remove the ten 1mm Phillips #0 screws that are securing the battery in place.
  5. Sony Vaio Fit 13A Battery Replacement: step 5, image 1 of 2 Sony Vaio Fit 13A Battery Replacement: step 5, image 2 of 2
    • Remove the battery with the Plastic Opening Tool by placing the tool between the battery and the computer and cautiously prying it out.
3 other people completed this guide.
Alex Prange
527 Reputation
3 Guides authored
Cal Poly, Team 21-19, Maness Winter 2015 Member of Cal Poly, Team 21-19, Maness Winter 2015
CPSU-MANESS-W15S21G19
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 22
All Time: 7,827
