Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement
  1. Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement, Back Cover: step 1, image 1 of 2 Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement, Back Cover: step 1, image 2 of 2
    • Starting with the laptop top-down, locate and remove the twelve 1mm Phillips #0 screws securing the back cover to the main body of the computer.
  2. Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement: step 2, image 1 of 2 Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement: step 2, image 2 of 2
    • Use the Plastic Opening Tools or Metal Spudger to carefully loosen back cover from the body of the computer.
    • Be sure to avoid headphone jack when removing back cover by lifting cover away from computer and up.
  3. Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement: step 3, image 1 of 1
    • Lift off back cover to access inner components of computer.
  4. Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement, Fan: step 4, image 1 of 2 Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement, Fan: step 4, image 2 of 2
    • Remove the three 1mm Phillips #0 screws surrounding the fan.
    • Loosen the three 1mm Phillips #0 screws. These screws will stay captive to the heatsink.
  5. Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement: step 5, image 1 of 3 Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement: step 5, image 2 of 3 Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement: step 5, image 3 of 3
    Tool used on this step:
    Buy
    • Use tweezers to carefully unplug the fan connector.
  6. Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement, Remove the Fan: step 6, image 1 of 2 Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement, Remove the Fan: step 6, image 2 of 2
    • Use the Plastic Opening Tool to gently remove the heat sink and fan assembly from the computer.
    • Important: Follow the How to Apply Thermal Paste guide to replace the thermal paste before reassembling your device.
4 other people completed this guide.
Marii
658 Reputation
3 Guides authored
Cal Poly, Team 21-19, Maness Winter 2015 Member of Cal Poly, Team 21-19, Maness Winter 2015
CPSU-MANESS-W15S21G19
4 Members
12 Guides authored
One Comment
Could you also maybe do a tutorial on Sony Vaio Fit 13? http://www.laptoppartstore.com/replace--... Any luck figuring out how the fan may be detached and re-attached to the heatsink? Also, I notice a very specific type of taping... where can one procure those?
Abhishek D - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 16
All Time: 4,566
