Sony Vaio Fit 13A SVF13NA1EL Screen Connector
  1. Sony Vaio Fit 13A SVF13NA1EL Screen Connector, Sony Vaio Fit 13A SVF13NA1EL Screen Connector: step 1, image 1 of 1
    • Flip over the screen
    • Remove all 8 screws as shown circled in the image using a Phillips #0
  2. Sony Vaio Fit 13A SVF13NA1EL Screen Connector: step 2, image 1 of 3 Sony Vaio Fit 13A SVF13NA1EL Screen Connector: step 2, image 2 of 3 Sony Vaio Fit 13A SVF13NA1EL Screen Connector: step 2, image 3 of 3
    • Flip the screen back over.
    • Use a plastic spudger to remove the top section of the cover.
  3. Sony Vaio Fit 13A SVF13NA1EL Screen Connector: step 3, image 1 of 1
    • Unplug the screen connecter from the back of the screen.
  4. Sony Vaio Fit 13A SVF13NA1EL Screen Connector: step 4, image 1 of 1
    • Disconnect the ribbon wire from the LCD connector by gently pulling it.
  5. Sony Vaio Fit 13A SVF13NA1EL Screen Connector: step 5, image 1 of 2 Sony Vaio Fit 13A SVF13NA1EL Screen Connector: step 5, image 2 of 2
    • Gently raise the metal framework of the laptop to reveal the remaining portion of the screen connector.
    • Follow the ribbon wiring to where it connects to the screen.
    • Carefully pull the wiring to disconnect and click it back in place to reconnect.
4 other people completed this guide.
5 Comments
Where to buy or to repair screen connector for Vaio Fit SVF13N13
Adham Ahmed - Reply
Where to replace the keyboard of Vaio SVF13N2
Arturo Dameno - Reply
Where i buy flexi
msobirin48 - Reply
The procedure is nicely explained
Is there an option to replace the LCD flet cable ... ?
It is complicated but we found a defect on the flet cable.
servis računara - Reply
I found some spareparts over the sony website. With all data from you laptop you can find them here https://uk.eetgroup.com/Guide/m/Sony-VAI...
Lukas Lutz - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 31
All Time: 4,253
