Sony Vaio PCG-4121GL Battery Replacement
  1. Sony Vaio PCG-4121GL Battery Replacement, Battery: step 1, image 1 of 2 Sony Vaio PCG-4121GL Battery Replacement, Battery: step 1, image 2 of 2
    • Remove the two 3mm Phillips #0 screws on the bottom of the computer that secure the plastic backing.
  2. Sony Vaio PCG-4121GL Battery Replacement: step 2, image 1 of 3 Sony Vaio PCG-4121GL Battery Replacement: step 2, image 2 of 3 Sony Vaio PCG-4121GL Battery Replacement: step 2, image 3 of 3
    • Pull the bottom plate towards yourself until it unhinges fully.
    • Once the plate is free from the backing remove it completely.
  3. Sony Vaio PCG-4121GL Battery Replacement: step 3, image 1 of 1
    • Look for the blue tab that is located to the bottom left of the battery.
  4. Sony Vaio PCG-4121GL Battery Replacement: step 4, image 1 of 3 Sony Vaio PCG-4121GL Battery Replacement: step 4, image 2 of 3 Sony Vaio PCG-4121GL Battery Replacement: step 4, image 3 of 3
    • Pull the blue tab towards yourself until you hear a click.
    • Once the blue tab is released, pull up on the battery.
    • Once the battery can move freely, take it out completely.
    • It may be helpful to have a spudger to make it easier to release the blue tab.
McKinley Hubred
127 Reputation
1 Guide authored
Cal Poly, Team S2-G2, White Winter 2019 Member of Cal Poly, Team S2-G2, White Winter 2019
CPSU-WHITE-W19S2G2
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 51
All Time: 2,814
