Sony Vaio PCG-4121GL Keyboard Replacement
  1. Sony Vaio PCG-4121GL Keyboard Replacement, Battery: step 1, image 1 of 2 Sony Vaio PCG-4121GL Keyboard Replacement, Battery: step 1, image 2 of 2
    • Remove the two 3mm Phillips #0 screws on the bottom of the computer that secure the plastic backing.
  2. Sony Vaio PCG-4121GL Keyboard Replacement: step 2, image 1 of 3 Sony Vaio PCG-4121GL Keyboard Replacement: step 2, image 2 of 3 Sony Vaio PCG-4121GL Keyboard Replacement: step 2, image 3 of 3
    • Pull the bottom plate towards yourself until it unhinges fully.
    • Once the plate is free from the backing remove it completely.
  3. Sony Vaio PCG-4121GL Keyboard Replacement: step 3, image 1 of 1
    • Look for the blue tab that is located to the bottom left of the battery.
  4. Sony Vaio PCG-4121GL Keyboard Replacement: step 4, image 1 of 3 Sony Vaio PCG-4121GL Keyboard Replacement: step 4, image 2 of 3 Sony Vaio PCG-4121GL Keyboard Replacement: step 4, image 3 of 3
    • Pull the blue tab towards yourself until you hear a click.
    • Once the blue tab is released, pull up on the battery.
    • Once the battery can move freely, take it out completely.
    • It may be helpful to have a spudger to make it easier to release the blue tab.
  5. Sony Vaio PCG-4121GL Keyboard Replacement, Keyboard: step 5, image 1 of 2 Sony Vaio PCG-4121GL Keyboard Replacement, Keyboard: step 5, image 2 of 2
    • Remove seven 3mm Phillips #0 screws from the bottom of the computer.
    • Remove eight 5mm Phillips #0 screws.
  6. Sony Vaio PCG-4121GL Keyboard Replacement: step 6, image 1 of 3 Sony Vaio PCG-4121GL Keyboard Replacement: step 6, image 2 of 3 Sony Vaio PCG-4121GL Keyboard Replacement: step 6, image 3 of 3
    • Carefully remove the disk drive from its compartment.
  7. Sony Vaio PCG-4121GL Keyboard Replacement: step 7, image 1 of 2 Sony Vaio PCG-4121GL Keyboard Replacement: step 7, image 2 of 2
    • Remove the three 2mm Phillips #00 screws located on the top right edge.
  8. Sony Vaio PCG-4121GL Keyboard Replacement: step 8, image 1 of 3 Sony Vaio PCG-4121GL Keyboard Replacement: step 8, image 2 of 3 Sony Vaio PCG-4121GL Keyboard Replacement: step 8, image 3 of 3
    • Gently pull apart the top and bottom plastic bodies.
    • Carefully lift up tabs to detach cable connectors.
    • Slowly detach bottom component to avoid tearing wires/connectors.
  9. Sony Vaio PCG-4121GL Keyboard Replacement: step 9, image 1 of 3 Sony Vaio PCG-4121GL Keyboard Replacement: step 9, image 2 of 3 Sony Vaio PCG-4121GL Keyboard Replacement: step 9, image 3 of 3
    • Remove the tape strips along the edge of the keyboard.
    • Once the keyboard is disconnected, slowly poke out keys one-by-one.
    • When the keyboard is free to move, remove it completely.
    • The keyboard is held in place with glue, once it is removed it is likely that it will not go back in the same way.
2 other people completed this guide.
Miguel Camarena
367 Reputation
3 Guides authored
Cal Poly, Team S2-G2, White Winter 2019 Member of Cal Poly, Team S2-G2, White Winter 2019
CPSU-WHITE-W19S2G2
4 Members
10 Guides authored
One Comment
Im having trouble putting the keyboard cables back
Ishaan Patel - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 26
All Time: 1,702
