Sony Vaio PCG-4G1L Optical Drive Replacement
  1. Sony Vaio PCG-4G1L Optical Drive Replacement, Battery: step 1, image 1 of 1
    • Turn off the computer and disconnect the charging cable.
    • Failing to unplug the cable can result in electric shock.
  2. Sony Vaio PCG-4G1L Optical Drive Replacement: step 2, image 1 of 2 Sony Vaio PCG-4G1L Optical Drive Replacement: step 2, image 2 of 2
    • Slide battery release toggle switch towards the "RELEASE" print.
  3. Sony Vaio PCG-4G1L Optical Drive Replacement: step 3, image 1 of 3 Sony Vaio PCG-4G1L Optical Drive Replacement: step 3, image 2 of 3 Sony Vaio PCG-4G1L Optical Drive Replacement: step 3, image 3 of 3
    • Apply pressure with your thumb on the grip.
    • Pull the battery out while simultaneously holding the battery release toggle switch in the release position.
  4. Sony Vaio PCG-4G1L Optical Drive Replacement, Keyboard: step 4, image 1 of 2 Sony Vaio PCG-4G1L Optical Drive Replacement, Keyboard: step 4, image 2 of 2
    • Remove one 5 mm Phillips #1 pan head screw, in the middle of the laptop, using a Bit Driver with Phillips PH1 bit.
  5. Sony Vaio PCG-4G1L Optical Drive Replacement: step 5, image 1 of 2 Sony Vaio PCG-4G1L Optical Drive Replacement: step 5, image 2 of 2
    • Be sure to pry the plastic opening tool under the keyboard, rather than under the keys. Otherwise, some keys could get harmed.
    • While using a plastic opening tool, carefully lift the keyboard by inserting the tool under the edge.
  6. Sony Vaio PCG-4G1L Optical Drive Replacement: step 6, image 1 of 3 Sony Vaio PCG-4G1L Optical Drive Replacement: step 6, image 2 of 3 Sony Vaio PCG-4G1L Optical Drive Replacement: step 6, image 3 of 3
    • Do not pull the keyboard too far away, as a ribbon cable is still attached. Failing to do so can cause damage to the ribbon cable or the connector.
    • Use the plastic opening tool to release the clamp.
    • Using slight pressure, remove the ribbon cable with your fingers.
  7. Sony Vaio PCG-4G1L Optical Drive Replacement, Network Antenna: step 7, image 1 of 1
    • Swivel the Network Antenna up so that it points upward.
  8. Sony Vaio PCG-4G1L Optical Drive Replacement: step 8, image 1 of 2 Sony Vaio PCG-4G1L Optical Drive Replacement: step 8, image 2 of 2
    • Pinch thumb and index finger at the Network Antenna's base.
    • Make sure not to bend the Network Antenna. Failing to do so can cause damage to the antenna.
    • Pull the Network Antenna off.
  9. Sony Vaio PCG-4G1L Optical Drive Replacement, Plastic Casing: step 9, image 1 of 2 Sony Vaio PCG-4G1L Optical Drive Replacement, Plastic Casing: step 9, image 2 of 2
    • Remove seven 5 mm Phillips #1 pan head screws with a Bit Driver, using a Phillips PH1 bit.
  10. Sony Vaio PCG-4G1L Optical Drive Replacement: step 10, image 1 of 2 Sony Vaio PCG-4G1L Optical Drive Replacement: step 10, image 2 of 2
    • Remove one 7 mm Phillips #1 Pan Head Screw by using a Bit Driver with Phillips PH1 bit.
  11. Sony Vaio PCG-4G1L Optical Drive Replacement: step 11, image 1 of 2 Sony Vaio PCG-4G1L Optical Drive Replacement: step 11, image 2 of 2
    Tool used on this step:
    Buy
    • Disconnect the cable by using the precision tweezers.
    • Slowly pry out the ribbon cable by using the plastic opening tool.
  12. Sony Vaio PCG-4G1L Optical Drive Replacement: step 12, image 1 of 1
    • Do not pull the plastic cover too far away, as a ribbon cable is still attached. Failing to do so can cause damage to ribbon cable or the connector.
    • Remove the plastic cover by inserting the plastic opening tool around the edge.
  13. Sony Vaio PCG-4G1L Optical Drive Replacement: step 13, image 1 of 2 Sony Vaio PCG-4G1L Optical Drive Replacement: step 13, image 2 of 2
    • Disconnect the ribbon cable by pulling straight up with your fingers.
  14. Sony Vaio PCG-4G1L Optical Drive Replacement, Optical Drive: step 14, image 1 of 2 Sony Vaio PCG-4G1L Optical Drive Replacement, Optical Drive: step 14, image 2 of 2
    • Insert the PH0.8 bit into the pin hole to eject the optical drive.
  15. Sony Vaio PCG-4G1L Optical Drive Replacement: step 15, image 1 of 2 Sony Vaio PCG-4G1L Optical Drive Replacement: step 15, image 2 of 2
    • Remove one 4mm Phillips #0 pan head screw, using a Bit Driver with a Phillips PH000 bit.
    • Remove three 5mm Phillips #0 flat head screws, using a Bit Driver with a Phillips PH000 bit.
  16. Sony Vaio PCG-4G1L Optical Drive Replacement: step 16, image 1 of 2 Sony Vaio PCG-4G1L Optical Drive Replacement: step 16, image 2 of 2
    • Apply pressure to the ribbon cable, then pick up and pull the optical drive away from the cable.
Cole Collins
193 Reputation
4 Guides authored
USF Tampa, Team 2-3, Cagle Fall 2016 Member of USF Tampa, Team 2-3, Cagle Fall 2016
USFT-CAGLE-F16S2G3
5 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 622
