Sony Vaio VGN-SR140E Hard Drive Replacement
Jeremy
Jeremy and 3 other contributors
Last updated on November 20, 2022
10 - 20 minutes
Moderate
Action Shots
Introduction
Go to step 1
The battery will need to be removed before servicing or replacing anything else on the device. The hard drive can be taken out after removing two screws. Be careful when removing the hard drive as it is attached to the motherboard by a thin ribbon cable.
Tools
  • Phillips #1 Screwdriver
  • Spudger
    Spudger
  1. Sony Vaio VGN-SR140E Hard Drive Replacement, Battery: step 1, image 1 of 1
    • Turn the laptop over and orient it as shown in the figure.
  2. Sony Vaio VGN-SR140E Hard Drive Replacement: step 2, image 1 of 1
    • Slide the lock latch to the right to release the battery lock.
    • Slide and hold the release latch to the left.
  3. Sony Vaio VGN-SR140E Hard Drive Replacement: step 3, image 1 of 2 Sony Vaio VGN-SR140E Hard Drive Replacement: step 3, image 2 of 2
    • Use a fingernail or plastic opening tool lift the battery while holding the release latch.Rotate the battery up and away from you to remove it from the laptop.
  4. Sony Vaio VGN-SR140E Hard Drive Replacement, Hard Drive: step 4, image 1 of 1
    • Using a Phillips #1 screw driver, loosen both screws holding the cover in place. These screws are secured to the cover with retaining clips.
  5. Sony Vaio VGN-SR140E Hard Drive Replacement: step 5, image 1 of 1
    • Lift the cover with a fingernail or plastic opening tool from the side where the screws are present and lift it off to the left.
  6. Sony Vaio VGN-SR140E Hard Drive Replacement: step 6, image 1 of 1
    • The hard drive is covered by a thin, black, plastic flap. Gently lift the hard drive up and to the right.
    • Be careful not to damage the ribbon cable during this step.
  7. Sony Vaio VGN-SR140E Hard Drive Replacement: step 7, image 1 of 2 Sony Vaio VGN-SR140E Hard Drive Replacement: step 7, image 2 of 2
    • Use the spudger or a fingernail to carefully release the lock securing the ribbon cable to the motherboard.
  8. Sony Vaio VGN-SR140E Hard Drive Replacement: step 8, image 1 of 2 Sony Vaio VGN-SR140E Hard Drive Replacement: step 8, image 2 of 2
    • Grasp the ribbon cable carefully near the connector end. Remove it by pulling the cable away from the connector on the motherboard at a slightly upward angle.
Jeremy
722 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 1,014
