Sony Vaio VPCEB11FM Hard Drive Replacement
  1. Sony Vaio VPCEB11FM Hard Drive Replacement, Battery: step 1, image 1 of 1
    • Power down and disconnect the laptop from power supply.
    • Using your fingers, unlock the tab by pushing on the slide.
  2. Sony Vaio VPCEB11FM Hard Drive Replacement: step 2, image 1 of 1
    • While holding the release slide, use your thumb to lift the lip of the battery to pull it out.
  3. Sony Vaio VPCEB11FM Hard Drive Replacement: step 3, image 1 of 1
    • Pull the battery out.
  4. Sony Vaio VPCEB11FM Hard Drive Replacement, Hard Drive: step 4, image 1 of 2 Sony Vaio VPCEB11FM Hard Drive Replacement, Hard Drive: step 4, image 2 of 2
    • Using the Phillips #01 Screwdriver, remove the two 7mm screws.
  5. Sony Vaio VPCEB11FM Hard Drive Replacement: step 5, image 1 of 3 Sony Vaio VPCEB11FM Hard Drive Replacement: step 5, image 2 of 3 Sony Vaio VPCEB11FM Hard Drive Replacement: step 5, image 3 of 3
    • Use your fingers to pry the cover upward.
    • Unscrew the two 7mm screws.
    • Pull the plastic tab in the direction of the arrow to take out.
  6. Sony Vaio VPCEB11FM Hard Drive Replacement: step 6, image 1 of 2 Sony Vaio VPCEB11FM Hard Drive Replacement: step 6, image 2 of 2
    • Lift plug side first.
    • Remove all the way.
  7. Sony Vaio VPCEB11FM Hard Drive Replacement: step 7, image 1 of 3 Sony Vaio VPCEB11FM Hard Drive Replacement: step 7, image 2 of 3 Sony Vaio VPCEB11FM Hard Drive Replacement: step 7, image 3 of 3
    • Skip to next step if accessing other components.
    • Remove the 3mm screws with the Phillips #1 Screwdriver from hard drive bracket.
2 other people completed this guide.
Maxine Filcher
1,153 Reputation
8 Guides authored
UW Tacoma, Team 1-5, Rose Winter 2017 Member of UW Tacoma, Team 1-5, Rose Winter 2017
UWT-ROSE-W17S1G5
4 Members
16 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 17
All Time: 4,351
