Sony Vaio PCG-TR3A Teardown
Featured Document
  1. Sony Vaio PCG-TR3A Teardown, Removing The Battery: step 1, image 1 of 3 Sony Vaio PCG-TR3A Teardown, Removing The Battery: step 1, image 2 of 3 Sony Vaio PCG-TR3A Teardown, Removing The Battery: step 1, image 3 of 3
    • Unplug the power cable before removing the battery.
    • Slide the 2 sliders on the under side of the laptop to the unlock position, as shown.
    • Grasp the battery and tilt it out at an angle - not straight out.
  2. Sony Vaio PCG-TR3A Teardown, Removing Memory Cover/Replacing RAM: step 2, image 1 of 2 Sony Vaio PCG-TR3A Teardown, Removing Memory Cover/Replacing RAM: step 2, image 2 of 2
    • Unscrew the pictured screwed holding the memory cover in place.
    • Pry the cover open carefully (flathead screwdriver might help)
    • To remove the RAM memory sticks, push both metal pieces holding them in place outwards, and the sticks will pop up. -picture of RAM inside -
    • Pull the sticks out carefully. - Picture of the RAM stick -
    • Using a small spudger, pry up the two rubber feet to reveal the screw holes underneath.
  3. Sony Vaio PCG-TR3A Teardown, Removing Rear Cover: step 3, image 1 of 1
    • Unscrew the rest of the screws on the underside of the PCG-TR3A.
    • Note: for ease of reassembly, keep track of which screws go where.
  4. Sony Vaio PCG-TR3A Teardown, Removing Keyboard: step 4, image 1 of 2 Sony Vaio PCG-TR3A Teardown, Removing Keyboard: step 4, image 2 of 2
    • Flip the laptop over and open the display carefully - the keyboard and bezel will be loose.
    • Lift the keyboard away from the top carefully.
    • **WARNING** The keyboard has a connector to the motherboard. Disconnect this before completely removing it.
  5. Sony Vaio PCG-TR3A Teardown, Removing Trackpad and Palm Rest: step 5, image 1 of 2 Sony Vaio PCG-TR3A Teardown, Removing Trackpad and Palm Rest: step 5, image 2 of 2
    • Remove the one screw holding the top assembly on.
    • Unplug the trackpad connector from the board.
    • Maneuver the palm rest away from the bottom half of the machine. Both the palm rest and trackpad will come off together.
  6. Sony Vaio PCG-TR3A Teardown, Removing Hard Drive and Optical Drive: step 6, image 1 of 1
    • Remove the three screws holding the hard drive and optical drive in place.
    • Lift up on the connectors connecting the drives to the board and lift the drives up to remove them.
  7. Sony Vaio PCG-TR3A Teardown, Removing Wi-Fi Card: step 7, image 1 of 1
    • To remove Wi-Fi card, first disconnect both display wires on the top right.
    • Then slide both of the metal pieces holding it down outwards, and it will pop up.
    • Carefully pull it out.
  8. Sony Vaio PCG-TR3A Teardown, Removing The Motherboard: step 8, image 1 of 3 Sony Vaio PCG-TR3A Teardown, Removing The Motherboard: step 8, image 2 of 3 Sony Vaio PCG-TR3A Teardown, Removing The Motherboard: step 8, image 3 of 3
    • Remove the three screws holding the board in place.
    • Disconnect the ribbon cables connecting the daughterboards to the motherboard and the large connector in the middle of the board.
    • Lift up the board gently. There will be two connectors on the underside of the board. Disconnect them before completely removing the board.
2 other people completed this guide.
Attached Documents
Kobi
220 Reputation
1 Guide authored
One Comment
I've used this info at least twice over many years to disassemble a Sony TR3.. thank you to those who provided it!
Medtech1 - Reply
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 36
All Time: 797
