Sony Vaio Pro 13 Bottom Cover Replacement
  1. Sony Vaio Pro 13 Bottom Cover Replacement, Bottom Cover: step 1, image 1 of 2 Sony Vaio Pro 13 Bottom Cover Replacement, Bottom Cover: step 1, image 2 of 2
    • Remove cover for the extended battery connector. Use your finger nail or a plastic opening tool to remove it.
    • Remove the two rubber feet at the back of the computer, these can be removed in the same way.
  2. Sony Vaio Pro 13 Bottom Cover Replacement: step 2, image 1 of 2 Sony Vaio Pro 13 Bottom Cover Replacement: step 2, image 2 of 2
    • Remove the four 5.6mm Philips #00 screws located at the top of the computer.
    • Remove the eight 3.6mm Philips #00 screws on the base of the computer.
  3. Sony Vaio Pro 13 Bottom Cover Replacement: step 3, image 1 of 2 Sony Vaio Pro 13 Bottom Cover Replacement: step 3, image 2 of 2
    • Using a plastic opening tool, pry the plastic casing away from the base of the computer, the remaining clips around the edges can be released using your hands.
    • Leave the side with the USB and audio port until last, then slide the case out and off, so the audio port doesn't get caught.
7 other people completed this guide.
1 Guide Comment
Hi…I have same laptop, what your advice getting the cover back on? especially near the audio and usb ports…that my hang up
thanks
chrisrai - Reply Share
Past 24 Hours: 3
Past 7 Days: 9
Past 30 Days: 27
All Time: 7,602
