Sony Vaio SVE15112FXS Hard Drive Replacement
  1. Sony Vaio SVE15112FXS Hard Drive Replacement, Hard Drive: step 1, image 1 of 1
    • Power laptop off before beginning.
    • Turn the laptop over so that it is positioned top down with the model number facing you.
  2. Sony Vaio SVE15112FXS Hard Drive Replacement: step 2, image 1 of 1
    • Use a #0 Phillips screwdriver to remove the two 4.0 mm screws securing the hard drive cover.
    • To avoid losing any parts, we recommend that you place the loose screws on a magnetic project mat.
  3. Sony Vaio SVE15112FXS Hard Drive Replacement: step 3, image 1 of 2 Sony Vaio SVE15112FXS Hard Drive Replacement: step 3, image 2 of 2
    • To expose the hard drive, remove the cover by sliding it toward you and pulling up on the panel.
  4. Sony Vaio SVE15112FXS Hard Drive Replacement: step 4, image 1 of 1
    • Use a #0 Phillips screwdriver to remove the two 4.0 mm screws attaching the hard drive to the laptop.
  5. Sony Vaio SVE15112FXS Hard Drive Replacement: step 5, image 1 of 2 Sony Vaio SVE15112FXS Hard Drive Replacement: step 5, image 2 of 2
    • Pull the clear plastic ribbon to the left until the mount is detached from the laptop.
    • There will be some resistance as the hard drive is disconnected. If it does not move at all, check that all anchor screws are removed.
    • Lift the hard drive out of the well.
  6. Sony Vaio SVE15112FXS Hard Drive Replacement: step 6, image 1 of 2 Sony Vaio SVE15112FXS Hard Drive Replacement: step 6, image 2 of 2
    • Use a #0 Phillips screwdriver to remove the four 4.0 mm screws attaching the mount to the hard drive.
    • Slide the hard drive away from the mount until it is completely detached.
    • Take note of how the mount is positioned when attached to the hard drive.
Ashley Bierman
1,223 Reputation
5 Guides authored
Ohio State, Team S1-G1, Whitney Fall 2018 Member of Ohio State, Team S1-G1, Whitney Fall 2018
OSU-WHITNEY-F18S1G1
2 Members
10 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 29
All Time: 746
